if vs Ternary vs Direct Assignment
kda406
PostPosted: Tue Apr 30, 2019 9:16 am     Reply with quote
This is just a report, not a complaint or request. But if someone has a suggestion, I am open to other options too.
I have to test a bit in a UINT8 (aka short int or char) and save off the result into a BOOL for use elsewhere. I tried 3 approaches and what I found in the LST file was intriguing.
IF method uses 12 bytes of program memory:
if(gsPacket.iData[2] & 0x08) gLEDStatus.condensate = true; else gLEDStatus.condensate = false;
02148:  BTFSS  x73.3
0214A:  BRA    2152
0214C:  MOVLW  01
0214E:  MOVWF  xBC
02150:  BRA    2154
02152:  CLRF   xBC
But the "then" portion above only assigns a value to one single variable, so I can easily use...
Ternary method uses 12 bytes of program memory:
gLEDStatus.condensate = (gsPacket.iData[2] & 0x08) ? true : false;
02154:  BTFSS  x73.3
02156:  BRA    215C
02158:  MOVLW  01
0215A:  BRA    215E
0215C:  MOVLW  00
0215E:  MOVWF  xBC
But the value I am assigning is only true or false, which appears redundant in the ternary operation. It seems simplest to use...
Direct Assignment method uses 14 bytes of program memory:
gLEDStatus.condensate = ((gsPacket.iData[2] & 0x08) != 0);
02160:  MOVF   x73,W
02162:  ANDLW  08
02164:  BNZ   216A
02166:  MOVLW  00
02168:  BRA    216C
0216A:  MOVLW  01
0216C:  MOVWF  xBC
You can see from the assembly that the three operations accomplish the same goal in three different ways. This is not unexpected. The most fascinating part to me was that the tightest C code produced the largest assembly code. I felt compelled to share this with the community.
-Kyle
PostPosted: Tue Apr 30, 2019 9:29 am     Reply with quote
How about this one ?
..... gLEDStatus.condensate = bit_test(gsPacket.iData[2], 3);
00036:  CLRF   05
00038:  BTFSC  08.3
0003A:  INCF   05,F
Test program:
#include <18F87K22.h>
#fuses NOWDT
#use delay(internal=4M)
#use rs232(UART1, baud=9600, errors)
struct
int8 condensate;
}gLEDStatus;
struct
int8 iData[10];
}gsPacket;
while(TRUE);
kda406
PostPosted: Tue Apr 30, 2019 9:44 am     Reply with quote
Sweet. I generally stick with portable code, but this is fantastic and needs to be included in the thread.
CCS bit_test() uses 6 bytes of program memory:
gLEDStatus.condensate = bit_test(gsPacket.iData[2],3);
0216E:  CLRF   xBC
02170:  BTFSC  x73.3
02172:  INCF   xBC,F
Thanks PCM programmer for reminding me about this one.
PostPosted: Tue Apr 30, 2019 10:36 am     Reply with quote
Generally, ternary operations are not optimised in CCS. They don't skip
evaluation of the 'false' route for example, so I'm not surprised that
there is no gain from using these.
However the key point about 'bit_test', is it takes advantage of the processors
instruction set. The PIC has a fixed location 'bit test' instruction. With a
fixed bit, this can be used instead of having to mask out the required bit
and test this. Much more efficient as you have seen.
If you want to be portable, then code a macro, that when compiled on
CCS, uses the bit_test operation, but otherwise generates the mask and
does the logical test this way. Very Happy
kda406
PostPosted: Tue Apr 30, 2019 12:02 pm     Reply with quote
Just for completeness, my tests were with V5.085 compiled for a PIC18F67K40.
Ttelmah you make several great points, and I agree completely on the use of macros for portability. Very Happy
PostPosted: Tue Apr 30, 2019 5:08 pm     Reply with quote
hmm...
this..
02172: INCF xBC,F
wonder why CCS didn't use the BSF instruction ? After all they're testing a bit...seems to me logical to set a bit ?? No saving in time, both are 1 cycle.
just curious...
PostPosted: Wed May 01, 2019 1:21 am     Reply with quote
I wondered the same. I suspect the reason is so that the status bit for
non zero will be set. Hence if the result is used in the same C instruction
in a test (so where you do an assignment inside a test), this ensures the
status is set without having to test again. BSF, does not update the
status, while INCF does.
pmuldoon
PostPosted: Tue Jun 11, 2019 5:26 am     Reply with quote
Could it be because the operand is an int8 and not an int1?
Just taking a short break from work and stumbled across this cool thread.
