64bit Linux
Goto page Previous  1, 2, 3
ghamblin
64 Bit Linux
PostPosted: Thu Dec 24, 2020 5:54 pm     Reply with quote
I received my Christmas present today!!
64 Bit CCSC that works great!
Thanks, CCS!!!
-Glenn
brubbel
PostPosted: Mon Sep 13, 2021 9:47 am     Reply with quote
A libc version > libc-2.27.so will result in a segfault.
You can run the ccsc compiler just fine in docker with legacy libraries:
Dockerfile example:
FROM debian:stretch-slim
WORKDIR /tmp/
RUN set -ex
RUN echo 'debconf debconf/frontend select Noninteractive' | debconf-set-selections
RUN dpkg --add-architecture i386
RUN apt-get -y update
## SYSTEM PACKAGES
RUN apt-get -y --no-install-recommends install libc6:i386
ADD ccsc_install_dir /opt/ccsc_files
ENV PATH "$PATH:/opt/ccsc_files/"
CMD ["/bin/bash"]
2. Create an image YOUR_IMAGE from above dockerfile.
tar -czh . | docker build -f Dockerfile -t YOUR_IMAGE:1.0.0 -
3. Then run like this:
docker run -v /path/to/src:/tmp/src YOUR_IMAGE:1.0.0 bash -c "cd /tmp/src/; ccsc.bin +FM +A +T +EW main.c"
Page 3 of 3
