cvargcal
| Help with this function |
Posted: Sat Apr 06, 2019 11:42 pm |
I want use this function
| Code: | void SSD1306_DrawPixel(uint8_t x, uint8_t y, int1 color = TRUE) {
if ((x >= SSD1306_LCDWIDTH) || (y >= SSD1306_LCDHEIGHT)) return;
if (color) buffer[x + (uint16_t)(y / 8) * SSD1306_LCDWIDTH] |= (1 << (y & 7));
else buffer[x + (uint16_t)(y / 8) * SSD1306_LCDWIDTH] &= ~(1 << (y & 7));
I want draw any icon in buffer mapping
| Code: | void SSD1306_Drawicon(uint8_t x, uint8_t y, char *c, int16_t w, int16_t h) {
int16_t i, j, byteWidth = (w + 7) / 8;
uint8_t ptr;
for(i = 0; i < h; i++ ) {
ptr = c[i];
for(j = 0; j < w; j++, ptr >>= 1) {
if(ptr & 0x01) SSD1306_DrawPixel(x + i, y + j);
// if(bit_test(c[i], 7-j)) SSD1306_DrawPixel(x+i, y+j);
using
| Code: | const unsigned char bat_4 [32] = {
0xE0, 0xF0, 0xF8, 0x38, 0x38, 0x38, 0x38, 0x38, 0x38, 0xB8, 0xB8, 0x38, 0x38, 0xF0, 0xE0, 0x80,
0x07, 0x0F, 0x1F, 0x1C, 0x1C, 0x1D, 0x1F, 0x1F, 0x1D, 0x1D, 0x1D, 0x1D, 0x1C, 0x0F, 0x07, 0x01
SSD1306_DrawCharx(40,40,bat_4,16,16); |
The function work 50%, only keep half array of bat_4 in array buffer. When I display buffer, only show top part of icon.
My question is, how i can keep array bat_4, on array buffer but with postion x,y, buffer is of 1024, I am making bab the tranverse array. |
| Re: Help with this function |
Posted: Sun Apr 07, 2019 12:48 am |
| cvargcal wrote: |
uint8_t ptr;
ptr = c[i];
// using:
SSD1306_DrawCharx(40, 40, bat_4, 16, 16);
// The function work 50%
First, the variable that you call 'ptr' is not a pointer, it's the data.
It's just a byte of data from the bat_4 array. That's just an issue
of giving it a confusing name.
The real problem is that your width is 16 pixels, but your data (called 'ptr')
is only one byte of 8 bits. You need to be processing 2 bytes (16 bits) for
the width.
Also, what is the symbol 'bat_4' supposed to be ? Describe it. Is it
a rectangle that's partially filled up, like a battery would be partially full ? |
cvargcal
Posted: Sun Apr 07, 2019 2:14 am |
| PCM programmer wrote: | | cvargcal wrote: |
uint8_t ptr;
ptr = c[i];
// using:
the width.
Thanks you
the bat_0 is full, I tried with this but not show correct the pixel
| Code: | void drawXbm(int16_t xMove, int16_t yMove, int16_t width, int16_t height, char *xbm) {
int16_t widthInXbm = (width + 7) / 8;
uint8_t data = 0;
for(int16_t y = 0; y < height; y++) {
for(int16_t x = 0; x < width; x++ ) {
if (x & 7) {
data >>= 1; // Move a bit
} else { // Read new data every 8 bit
data = xbm[(x / 8) + y * widthInXbm];
// if there is a bit draw it
if (data & 0x01) {
SSD1306_DrawPixel(xMove + x, yMove + y);
Posted: Sun Apr 07, 2019 3:20 am |
Post a link to an image on a website that shows me what the bat_4 symbol
should look like.
For example, which one of these icons is bat_4 supposed to look like ?
https://www.freepik.com/free-vector/battery-icons-collection_1095897.htm
Also, those symbols are vertical. Is the bat_4 symbol vertical or horizontal ?
Be accurate and complete in your answer. |
cvargcal
Posted: Sun Apr 07, 2019 8:31 am |
| PCM programmer wrote: | Post a link to an image on a website that shows me what the bat_4 symbol
should look like.
Look,
full
| Code: | void SSD1306_Icon(char *icon, uint8_t seg, uint8_t pag, uint8_t _width, uint8_t _height){ //x,y
uint8_t i, j;
uint8_t x_seg, y_pag;
y_pag = pag;
for(i = 0; i < _height / 8; i++) {
x_seg = seg;
for(j = 0; j < _width; j++) {
SSD1306_SetPointer(x_seg, y_pag);
SSD1306_WriteRam(*icon); // Directamente al display
// buffer[x_seg + (y_pag * 128)] = *icon; // On buffer
icon++;
x_seg++;
y_pag++;
Half
| Code: | void SSD1306_DrawCharx(uint8_t x, uint8_t y, char *c, int16_t w, int16_t h,int size) {
uint8_t ptr;
ptr = c[i];
if(ptr & 0x01) SSD1306_DrawPixel(x + i, y + j); // else SSD1306_FillRect(x + (i * size), y + (j * size), size, size);
rares bit
uint8_t data = 0;
if (x & 7) {
if (data & 0x01) {
I can draw any icon, but the problem is that I have show with "pag ans seg" so I can not draw the icon where i want because the the PAG is 0...7, so if I start in PAG 0, I can not draw in top screen without over rectangle.
With the function drawpixel(x,y) I can draw all bits in buffer array with direction for after display all buffer. |
Posted: Sun Apr 07, 2019 8:33 am |
OK, looks like you're using Proteus and NOT real hardware .
Is this correct ? |
cvargcal
Posted: Sun Apr 07, 2019 8:44 am |
| temtronic wrote: | OK, looks like you're using Proteus and NOT real hardware .
Is this correct ? |
Yes, but its the same in real. I tested |
empty
Posted: Sun Apr 07, 2019 10:47 am |
Look, if you're using this driver:
https://simple-circuit.com/ssd1306-oled-ccs-c-library/
just use the function: SSD1306_ROMBMP( ...
you can print your icon wherever you want, for example:
SSD1306_Begin(SSD1306_SWITCHCAPVCC, SSD1306_I2C_ADDRESS);
SSD1306_ClearDisplay();
SSD1306_ROMBMP(0, 0, bat_4, 16, 16);
SSD1306_ROMBMP(40, 15, bat_4, 16, 16);
SSD1306_ROMBMP(80, 30, bat_4, 16, 16);
SSD1306_ROMBMP(111, 47, bat_4, 16, 16);
SSD1306_Display();
while (TRUE)
This is simulation result:
cvargcal
Posted: Sun Apr 07, 2019 11:25 am |
| empty wrote: | Look, if you're using this driver:
SSD1306_Display();
while (TRUE)
In that page these other lib , woooow I had the answer all time.
Thanks you!!! |
