Pin 4 MCLR on Pics
Rez
Pin 4 MCLR on Pics
PostPosted: Fri Feb 22, 2019 6:13 pm     Reply with quote
Does pin 4 need a 10k resistor going to the Vdd positive if it is not being used?
PostPosted: Fri Feb 22, 2019 6:56 pm     Reply with quote
Generally..yes... unless you can program the PIC with a fuse called 'nomclr'. Newer PICs have that option and it allows that pin to be reused as an input.
You'll have to read the datasheet for whatever PIC you're using, in the 'pinout description list' it'll say what the pin can be used for.
Rez
PostPosted: Sat Feb 23, 2019 12:23 pm     Reply with quote
The pics I use have the ability to use the nomclr fuse. If it is setup that way can I eliminate the resistor or should I still use it.
alan
PostPosted: Sat Feb 23, 2019 1:38 pm     Reply with quote
Always better to use a res on a input, otherwise chip may draw more power as the input may be in a undefined state. Can't connect to GND directly because then you can not program unless you use a jumper.
PostPosted: Sat Feb 23, 2019 1:57 pm     Reply with quote
There are some very dangerous things about the MCLR pin when NOMCLR
is used. It does not have protection to prevent it being taken above the
Vdd supply, and if it is taken above this it can trigger the start of
programming, or a reset even though MCLR is disabled. If you want to
use if as an input, you should add your own protection diode to it,
and like all inputs, it should not be allowed to float.
PostPosted: Sat Feb 23, 2019 4:03 pm     Reply with quote
Some PICs, like 16F648a can't be programmed with a PICkit3 if you select internal osc and nomclr... found that out this week.... Crying or Very sad
I have seen _mclr tied to VDD on a couple products. Don't know if that is 'legal'....just something I saw some time ago....
PostPosted: Sun Feb 24, 2019 3:14 am     Reply with quote
This is a known bug with the Pickit3. The original software scripting tool
for this works. The later IPE tool doesn't, if NOMCLR is selected on some
devices!...
Eeek. Sad
There is a workaround, if the code does not set the other ICSP pins as
output within about a second of starting. If you add a delay of about
a second into your code at boot, before setting the pin TRIS, you will
find the device remains programmable. This was documented on the
MicroChip forums about four years ago.
<https://www.microchip.com/forums/m801016.aspx>
PostPosted: Sun Feb 24, 2019 6:28 am     Reply with quote
Thanks Mr. T ! Will try that out as my 'workaround' was to just use an 18F46K22. Tad 'overkill' for a 2 input, 2 output project. I like to keep the ICSP pins as ICSP pins so an 18 pin PIC like the 628, 648a seemed easy...
One day your head's going to explode with the knowledge stored up there !!
