USB with PIC24EP512GU810
maier
PostPosted: Tue Feb 19, 2019 9:31 am     Reply with quote
I'm trying to get this PIC USB to work. I copied the code and descriptor from a working project (other PIC), but it doesn't work (Error requesting the USB device descriptor, Code 43).
#include <24EP512GU810.h>
#device ICSP=1
#use delay(osc=24MHZ, clock=48MHZ, USB)
#FUSES NOWDT                   //No Watch Dog Timer
#FUSES CKSFSM                  //Clock Switching is enabled
#FUSES BROWNOUT
#FUSES NOJTAG                  //JTAG disabled
#FUSES NODEBUG
#define EP1            1
#include <pic24_usb.h>        //Microchip PIC18 hardware layer for usb.c
#include "usb_desc_hid.h"      //USB Device descriptor
#include <usb.c>
#define SIZE 8
void main( void )
    char inbuf[SIZE];
    char outbuf[SIZE];
   usb_init_cs();
   while(TRUE) {
      usb_task();
      if(usb_enumerated()) {
         if (usb_kbhit(EP1)) {
            usb_get_packet(EP1,inbuf,SIZE);
            if (inbuf[0]==10) {
               outbuf[0]='o';
               outbuf[1]='k';
               outbuf[2]=0;
            usb_puts(EP1, outbuf, SIZE, 100 );
Anybody recognize a mistake?
Or is there something special to consider with this PIC?
Is there a way to measure the oscillator? If you could get the PIC to output to USB with a few lines, you could use an oscilloscope to verify the frequency. This would certainly be a very helpful feature for many developers
Uli
PostPosted: Tue Feb 19, 2019 10:13 am     Reply with quote
I don't use that PIC but...
this...
seems 'wrong' ? Would the pic24 need a PIC 24 HW layer and not PIC18 HW layer ??
I gave up with embedded USB PICs years ago. It's simpler,easier, cheaper to just buy a TTL<>USB module. I've bought dozens over the years and all have worked without any problems.
