CCS support for version checking at compile time? [Solved]
newguy
PostPosted: Fri Feb 15, 2019 3:26 pm     Reply with quote
I've searched and either I'm not using the proper keywords or what I'm looking for doesn't exist.
Does CCS have some kind of support for a compiler environment check? For example, let's say I create a project and eventually release something. I use compiler version 5.x, and leave comments in the code saying as much. A colleague then edits the project to make a minor change but uses compiler version 5.y and - for argument's sake - something breaks.
It would be useful to force the compiler to check what compiler version is actually being used, and generate an error if it's not what it is supposed to be.
I realize that I could simply put in a
#warning Version 5.x must be used!!!
but that would assume that people read compiler warnings.
Anyone know if this is supported?
newguy
PostPosted: Fri Feb 15, 2019 3:38 pm     Reply with quote
Nevermind: I knew I had seen something about compiler version checking/restriction. If you use the IDE, it's in Options->Project, General. Checkbox for "Use specific compiler version"
jeremiah
PostPosted: Fri Feb 15, 2019 6:59 pm     Reply with quote
We also do a precompiler check against the version and issue either a #warning or #error if the compiler version doesn't match.
Something like:
#if getenv("VERSION") != 5.080
   #error Using wrong compiler version
#endif
newguy
PostPosted: Sun Feb 17, 2019 2:15 pm     Reply with quote
That's exactly what I was looking for. Cheers!
bkamen
PostPosted: Thu Feb 28, 2019 1:21 am     Reply with quote
Don't forget to change the OP subject to include "SOLVED" somehow.
-Ben
