Ömer Faruk
| 1000000 writings on Eeprom |
Posted: Tue Jan 01, 2019 3:11 am |
Hello everyone
In pic16f877a datasheet there is such a part
• 1,000,000 erase/write cycle Data EEPROM
memory typical.
If i only write a constant data on one specific address in every millisecond what happens in 16.7 minutes ? (1000000 milliseconds is equal to 16.7 minutes)
Do these writings spoil physical address? |
Posted: Tue Jan 01, 2019 3:49 am |
First thing, you can't write every mSec. The write takes between 4 and 8mSec to actually perform.
1M cycles, is the typical value. You should always look at the 'worst
case' value, since this is all that is actually guaranteed.
So writing every 10mSec say, you have a warranted 'life' of 100K cycles.
Gives the same 16.7 minutes.
Yes. The probability of the cell dying starts to appear at this point, and by
perhaps 167minutes, shifts from 'may happen' to 'becoming almost certain'.
You should never use EEPROM like this.
Store the value in RAM or something more durable.
Series of possibilities:
1) Add an external clock chip. Many of these offer 'battery backed' RAM.
2) Add just a battery backed RAM.
3) Implement a 'power fail' interrupt on the PIC, with a supply that can
be guaranteed to be maintained for long enough after this to allow the
value to be written to EEPROM after the power fail is detected.
4) Use an 'infinite life' storage technology, like FRAM. |
Ömer Faruk
Posted: Tue Jan 01, 2019 4:15 am |
| Ttelmah wrote: |
Thank you very much for your reply. In my program i have a set value. I can increase or decrease this value. I need to store it.
1) Could you write me a popular external 'Battery backed' RAM for examining ?
3) How can i implement power fail interrupt and hardware ?
Please show me the way. |
Posted: Tue Jan 01, 2019 6:03 am |
What kind of hardware you need depends on what you're trying to do.
first, the 877 is, well, obsolete, and should not be used for new designs. uChip offer several replacement PICs, all more powerful, pin compatible and cheaper !
2nd, how much 'data' do you need to store and how often ? If less than say 50 bytes, I'd use a DS1307 RTC chip/module. They are about $2 CDN and come with 56 bytes of battery backed user RAM. It's a great way to store a few variables that change 'all the time'. Bonus is a stable RTC that can interrupt the PIC at 1Hz. I use that as a 'PIC tic' to trigger events like LCD update of time, read sensors, etc.
Now if you want to store a lot of data, again use an RTC module, perhaps one with EEPROM like ...https://www.banggood.com/DS3231-AT24C32-IIC-High-Precision-Real-Time-Clock-Module-For-Arduino-p-81066.html?rmmds=search&cur_warehouse=CN....
I've used these for 2-3 years. They have a better RTC and a LOT of EEPROM. There are hundreds of choices.....
What you have to understand is that most external 'modules' these days use 3 volt devices, so you need to interface to them properly. An easy solution is to use a PIC that WILL run at 3 volts, that way you just hookup the PIC to peripheral.
If you need to use the 877, then as Mr. T says, save your data to RAM, and can be as simple at a 6v battery with 2 diodes in series. There is a lot of information on the web about 'battery backup for PICs', use Google !!
Ömer Faruk
Posted: Tue Jan 01, 2019 7:02 am |
| temtronic wrote: |
Thanks for your reply. Which uControllers can i use instead of pic16f877a especially cheapers |
Posted: Tue Jan 01, 2019 8:29 am |
If you simply go to the 16F877A page at uChip, it says:
'not recommended for new designs', and suggests the PIC16F18877 as the
direct replacement. Faster, 10* the RAM. 4* the ROM. Extra peripherals,
lower power. The price $1.16, against $4.26 for the older chip. Now honestly
there are dozens of even faster chips with more peripherals once you move
up to PIC8's, but as the PIC16 'direct replacement', this is the chip they
suggest. |
Posted: Tue Jan 01, 2019 9:50 am |
Before you buy a new PIC, make sure your programmer supports it.
Check the device support list for your programmer. The new PIC may
cost $2 but a new programmer may cost $50. |
Ömer Faruk
Posted: Tue Jan 01, 2019 10:03 am |
| Ttelmah wrote: | If you simply go to the 16F877A page at uChip, it says:
suggest. |
You are right but when i search this cheaper chip on the internet there is no sale. |
Posted: Tue Jan 01, 2019 10:52 am |
DigiKey, Mouser, Microchip direct sale. All list this.
Beware of 'ebay' chip sellers. Many are selling chips that have failed testing
or are poor copies of the real chips. Only buy from the main suppliers. |
Ömer Faruk
Posted: Tue Jan 01, 2019 11:13 am |
| Ttelmah wrote: | DigiKey, Mouser, Microchip direct sale. All list this.
I will try them thanks a lot. |
Posted: Wed Jan 02, 2019 1:42 am |
On the question 'how to implement a power fail detection', this depends totally
on how your board is powered.
Where the supply comes 'from' (DC source, battery, mains transformer)?.
How it is regulated?.
What else is powered from the PIC supply?. Can these devices be turned off
by the PIC?.
How many bytes need to be saved?.
The minimum current that can be achieved on the PIC's supply rail, determines
the reservoir needed to do the write (dependant on how many bytes have to
be written). The best way of detecting the power going 'off' depends on where
the supply actually comes from. |
Ömer Faruk
Posted: Wed Jan 02, 2019 2:53 am |
| Ttelmah wrote: |
The power supply 220V AC ->transformer->bridge rectifier-> filters >7805 regulator-> 5V |
Posted: Wed Jan 02, 2019 3:46 am |
OK. That's actually one of the easiest to do.
Look at a chip like the DS1231. Figure 5 in it's data sheet.
Choose the resistors so that the required sense voltage is given when the
output of the transformer is perhaps 80% of it's nominal figure.
Then as soon as the transformer voltage falls below this point the NMI
output will go low.
Feed this to an interrupt input on the PIC.
Have the code in the interrupt, write the EEPROM, and then sit reading
the INT input pin. If the pin goes high again, wait a few mSec, and then
return from the interrupt (this way the chip will carry on if the power is
restored).
All you need then to do is ensure that the capacitance on the supply rail
can maintain the 5v above the minimum voltage to write the EEPROM for
at least the time needed to write however many bytes are needed (give
at least a 50% margin on this). |
