Contagem de 5 em 5 no display, de 1 em 1 na 74595 (SOLVED)
emazzu630
PostPosted: Tue Dec 11, 2018 9:33 pm     Reply with quote
Já procurei na internet, mas não encontrei nada dessa natureza. Tenho o programa montado contando de 5 em 5 no display e no 74HC595. Preciso dividir por 5 para contar de 1 em 1 no 74HC595. No display precisa continuar contando de 5 em 5.
I've searched the internet, but I have not found anything of this nature. I have the program set counting by 5 in the display and in the 74HC595. I need to divide by 5 to count from 1 in 1 on the 74HC595. The display needs to continue counting by 5.
PostPosted: Wed Dec 12, 2018 3:27 am     Reply with quote
Not quite clear what you want to do, but if you have a count called 'count' say:
    int8 remainder, over5;
    //count called 'count' say
    over5=count/5;
    remainder=count % 5;
Will give 'over5', being count/5, and 'remainder' being the remainder from
division by 5.
Mike Walne
PostPosted: Wed Dec 12, 2018 7:44 am     Reply with quote
Show us your code and a diagram of your circuit.
Tell us what works and what does not.
Mike
emazzu630
PostPosted: Wed Dec 12, 2018 12:01 pm     Reply with quote
https://drive.google.com/file/d/1ji3VW3v5CzUglW-NBfw5eFBTMFy7T5IT/view?usp=sharing
https://www.4shared.com/photo/RD_aEzT3da/simulao.html
Na imagem acima o display conta de 5 em 5. Nos leds aparece o numero "15" em binário e no display também o numero "15". Eu preciso descobrir uma forma de ir fazendo a divisão por "5" para que no display fique "15" e em binário "3", mas isso nesse ritmo para qualquer numero que contar.
In the picture above the display counts by 5 in 5. In the leds the number "15" in binary appears and in the display also the number "15". I need to figure out a way to go by dividing by "5" so that the display is "15" and binary "3", but this at this rate for any number that counts.
unsigned int16 pulsa=0;
while(!input(up_5)||!input(dw_5)) {   //while 7 segmentos
   if (!input(up_5))
   var+=c;
   var-=c;
   int_to_seg(var);
   d++;
   if(!input(up_5)||!input(dw_5)){
   if(d>9) c=5;}
   delay_ms(delay);
   if(delay>=200)
   delay-=20;
   return var;
while(!input(up_5)||!input(dw_5)) {    //while 74hc595 binário
   if (!input(up_5))
   var+=e;
   var-=e;
   int_to_led(var);
   f++;
   if(f>9) e=1;}
   delay_ms(delay);
   if(delay>=200)
   delay-=20;
   return var;
while (true){
   pulsa=ajuste(pulsa);
O codigo acima está funcionando, mas ele só assume a contagem de 5 em 5, no display e nos leds. Eu preciso que ele assuma a contagem de 1 em 1 nos leds em binario.
PostPosted: Wed Dec 12, 2018 3:21 pm     Reply with quote
OK, maybe I'm reading this wrong , but if 1 press=5, 2 presses=10, ...,5=25, then
simply count 'presses' ,multiply by 5 save as a variable '5counts', and send this '5counts' data to the display.
PostPosted: Wed Dec 12, 2018 3:32 pm     Reply with quote
You want the LEDs to show the display value, divided by 5.
Make the changes shown in bold below:
if (!input(up_5))
var+=e;
var-=e;
// int_to_led(var);
int_to_led(var/5); // *** Divide var by 5 ***
f++;
if(f>9) e=1;}
delay_ms(delay);
if(delay>=200)
delay-=20;
return var;
emazzu630
PostPosted: Wed Dec 12, 2018 8:30 pm     Reply with quote
https://drive.google.com/file/d/1bDN7wKL6PqIe5Ip0WewfyfiaK4-7TvCQ/view?usp=sharing
https://drive.google.com/file/d/1wOFQ4_-Ry9jN532YUkag9-YDeCaqXi6H/view?usp=sharing
https://drive.google.com/file/d/1PRmwnyqxZYOLeISd0qMkBnw44PlsfnZ5/view?usp=sharing
Obrigado aos membros do fórum que se preocuparam em resolver a discussão. A solução apresentada pelo "PCM programmer" foi testada e funcionou. Nas imagens acima podemos ver o resultado
Thanks to forum members who have been concerned to resolve the discussion. The solution presented by "PCM programmer" was tested and worked. In the images above we can see the result.
