Global interrupt in pic 16f877
el-3aba6i
PostPosted: Thu Sep 20, 2018 1:04 am     Reply with quote
Can i use multiple interrupts in pic16f877a ?
I have this code:
#int_global
void global_interrupt () {
**code**
void main () {
**code**
enable_interrupts(global);
enable_interrupts(int_rda);
enable_interrupts(int_ext);
ext_int_edge(h_to_l);
Can this work???? and thanks for your help.
PostPosted: Thu Sep 20, 2018 1:36 am     Reply with quote
I think you are seriously misunderstanding interrupts.
Yes you can have multiple interrupts, if you get rid of the int_global handler.
Have a handler for #INT_EXT, and a handler for #INT_RDA. Each will be called when the corresponding interrupt triggers (remember that INT_RDA must read the serial port of this interrupt will never clear).
However if you have a #INT_GLOBAL handler, this replaces _all other interrupts_. It is called when any interrupt triggers. It must then contain your own code to save all variables used, and if multiple interrupts are used, it must poll all of them.
Get rid of the int_global handler, and then your other interrupts can behave normally. The INT_GLOBAL handler is only used if you are writing the entire interrupt handling system yourself.
You still need to enable #INT_GLOBAL. This is not in itself an 'interrupt', it is a 'master flag' allowing all interrupts to be enabled/disabled at once. If you use it as an 'interrupt', you are saying that you want to take over complete control of the interrupt system....
