Ancient vs current CCS struct differences?
SherpaDoug
PostPosted: Mon Sep 10, 2018 8:25 pm     Reply with quote
About 1998 I wrote this code which compiled and ran fine under PCB version 2.213.
struct {
  short   LEDBlink;         /* 1 enables blinking of LEDs */
  short   Redbit;            /* 1 turns on Red LED */
  short   Greenbit;         /* 1 turns on Green LED */
  short   D_Trig;            /* 1 when Diver Trigger is active */
  short   PressE;             /* 1 when pressure readings are enabled */
  int     Reserved: 3;        /* make sure rest of byte is unused */
} Misc_bits;
output_bit(RedLED,~input(RedLED)& Misc_bits.Redbit);
Misc_bits &= 0b11111000;
But this code does not compile under my current PCB 5.060. The last line setting Misc_bits as a whole gives Error 36 "A numeric expression must appear here". Note that the struct is 1 byte long. I suppose I could try to install PCB version 2.213 on Windows10 but I would rather move forwards than backwards.
Reading the new manual it seems I should be using a struct in a union to access a byte either as an int8 or as bits. But if I try the union example straight out of the manual it fails to compile.
union u_tab{
   int ival;
   long ival;
   float ival;
Gives the Error 31 "Identifier is already used in this scope" for long ival.
Has the behavior of structs and unions changed in CCS? Do unions work in PCB 5.060? Is there a better way to do this?
Here is a short program that used to compile and run under PCB version 2.213.
#include <16C58a.H>
#include <CTYPE.H>
#fuses HS,WDT,NOPROTECT
#use standard_io(a)
#use standard_io(b)
#use delay(clock=7372800)   /* 7.3728 MHz clock */
#byte   portB = 6
#define   Sio         PIN_B0   /* Bidirectional serial line to deckbox */
#use RS232(baud= 1200, xmit=PIN_B0, rcv=PIN_B0, invert)//#use RS232(baud= 1200, xmit=PIN_B1, rcv=PIN_B0)
#define DTrig      PIN_B1   /* Diver Trigger input */
#define RedLED      PIN_B2   /* Red diver trigger LED */
#define GrnLED      PIN_B3   /* Green diver trigger LED */
#define CSGain      PIN_B4   /* Chip Select\ for Gain Control DS1804 */
#define CSAD      PIN_B5   /* Chip select\ for A/D MAX187 */
#define Dclk      PIN_B6   /* Data Clock for DS1804 and MAX187 */
#define Data      PIN_B7   /* MAX187 data and DS1804 Up/Down */
struct {
} Misc_bits;
char   comms;            /* incomming char buffer */
main() {
   Misc_bits.PressE = 0;   /* disable pressure readings until cal is read */
   setup_counters(RTCC_INTERNAL,WDT_2304MS); /* RTCC to time Thermistor */
   output_bit(Sio,Misc_bits.D_Trig);   /* Send diver trigger flag status */
   while (true) {         /* wait for input */
      if(kbhit()) {      /* start of serial message */
         comms = getch();
         comms &= 0b00000111;            /* only 3 LSBs are setable */
         Misc_bits |= comms;
         Misc_bits.LEDBlink = Misc_bits & 0b00000010;
      if (Misc_bits.LEDBlink) {         /* If Blink enabled, toggle enabled LEDS */
         output_bit(GrnLED,~input(GrnLED)& Misc_bits.Greenbit);
      delay_ms(10);
PostPosted: Mon Sep 10, 2018 11:43 pm     Reply with quote
I was able to make it compile, and get apparent good results in the .LST
file by making the changes shown in bold below:
(int8)Misc_bits &= 0b11111000;
(int8)Misc_bits |= comms;
Misc_bits.LEDBlink = (int1)((int8)Misc_bits & 0b00000010);
I'm not sure if you're doing your 3rd line correctly. By ANDing with 10
you are testing to see if Redbit is set = 1. If so, then set LEDBlink=1.
Is that really what you want to do ? If it is, then casting the expression
to a boolean (ie., True/False) with (int1) is the way to go.
SherpaDoug
PostPosted: Tue Sep 11, 2018 6:43 pm     Reply with quote
Thanks, that fixed things. But trying to understand the problem, I guess a struct doesn't have a data type unless you force one upon it by casting? I guess the old compiler didn't check and just did the obvious, and that worked.
PostPosted: Wed Sep 12, 2018 12:23 pm     Reply with quote
I think that's the best explanation.
PostPosted: Sat Sep 15, 2018 12:55 am     Reply with quote
As some comments to this:
The reason the union did not work, was that you are calling all three parts the same name. Once the name is used inside the union, the other parts have to have different names. The example uses ival, lval, and fval, not all called ival as you post....
About 5.050ish, CCS introduced 'strong typing' for pointers. So it'll complain if pointer types do not match. It looks as if at the same time they allocated a 'type' to the structure name (probably void *), so if used as a pointer it has to be cast. However...
Technically in C, the structure name is not a pointer to the structure. It is actually an alias for the user defined type created by the structure. So the correct way to get it's address is:
&Misc_bits
it does still seem to be accepting it as the pointer (with suitable casting), but better really to use the & syntax that will then be correct C.
SherpaDoug
PostPosted: Sat Sep 22, 2018 1:18 pm     Reply with quote
Ttelmah, would this be proper by-the-book and easily understood C syntax?
struct {
} Misc_bits;
union miscellanious{
   int Misc_bits;
   int Misc_byte;
output_bit(RedLED, Misc_bits.Redbit);
Misc_byte &= 0xF7;
PostPosted: Sat Sep 22, 2018 1:54 pm     Reply with quote
You don't have a variable called 'Misc_byte'. You have one called miscellanious. However this does not talk to the same memory as your Misc_bits.
struct bts {
union {
   struct bts bits;
   unsigned int8  byte;
} Misc;
//Then
output_bit(RedLED, Misc.bits.Redbit); //Note . not _
Misc.byte &=0xF7;
This declares a union called Misc, containing an unsigned int8, and a struct bts, in the same memory space.
SherpaDoug
PostPosted: Mon Sep 24, 2018 9:00 pm     Reply with quote
For future readers, here is a fully compilable example of how to use a struct in a union.
#include <16F877.h>
#use delay(clock=10000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, BRGH1OK)
char comms;
struct bitalloctype {
   short LEDBlink;
   short Redbit;
   short Greenbit;
   int Reserved: 5;
};  //bitallocvar;
union {
   struct bitalloctype mbits;
   int8 mbyte;
} Misc;
   comms=getc();
   output_bit(RedLED, Misc.mbits.Redbit);
   Misc.mbyte &= 0xF7;
   printf(Misc.mbyte);
PostPosted: Fri Sep 28, 2018 12:29 pm     Reply with quote
As an additional note, CCS does support anonymous structs, so you can change it up a bit if you like:
union {
   struct {
      short LEDBlink;
      short Redbit;
      short Greenbit;
      int Reserved: 5;
   int8 mbyte;
} Misc;
   output_bit(RedLED, Misc.Redbit);
   Misc.mbyte &= 0xF7;
   printf(Misc.mbyte);
