PCH 3.152 with MPlab 6.20
Cam Bruce
PostPosted: Thu Jun 19, 2003 2:29 pm     Reply with quote
I just made the leap, in order to program 18F542's.
I have tried the simple program below, but when I build it, I get a "MPlab.exe has generated errors and will be closed by Windows. You will need to restart the program. An error log is being created" Then MPLab shuts down.
I installed MPlab 6.2, then CCS PCH 3.152, then the patch mentioned on this forum.
I created a project by:Project Wizard, selected 18F452, Show all installed toolsuites,Active Toolsuite = CCS C Compiler PIC 12/14/16/18, Location C:\program Files\PICC\CSCC.exe.
Names it, added the following source file. Built it, Killed it !
//// Blink_LED.C ////
//// Simple Program for the ////
//// 18F452 PIC. ////
//// For starters, it will flash ////
//// an LED on Pin 34 (RB1) ////
#include <18f452.h>
#fuses HS,NOPROTECT
#define LED Pin_B1
Void Main() {
OUTPUT_HIGH(LED); //LED OFF
delay_ms(500); //wait
output_low(LED); //LED ON
} //end of While(True), do it again
I am going to uninstall, and start again.
Any Other Suggestions ?
Cam
Original Post ID: 144515404
Dave Rolleman
Re: PCH 3.152 with MPlab 6.20
PostPosted: Thu Jun 19, 2003 4:05 pm     Reply with quote
Don't use the wizzard create the project then go back and set all the info manually, this doesn't crash.
:=Thanks
:=Cam
Original Post ID: 144515409
Cam Bruce
PostPosted: Thu Jun 19, 2003 11:33 pm     Reply with quote
I'll give that a try first thing in the morning.
I'll let you know. Thanks for the suggestion.
Cam
:=Don't use the wizzard create the project then go back and set all the info manually, this doesn't crash.
:=:=Thanks
:=:=Cam
Original Post ID: 144515414
Cam Bruce
PostPosted: Fri Jun 20, 2003 9:19 am     Reply with quote
Tried it, still crashes.
However. I used one of the Examples (Ex_tones.C) with the header changed to 18F452, and it works !
I don't have a reason for the crashes yet, but I think i am back on my feet.
:=:=Thanks
:=:=Cam
Original Post ID: 144515428
