SEQUENCE expected is not there in hardware output
Roopa K
PostPosted: Thu May 31, 2018 5:03 am     Reply with quote
I am new to pic controller programming. I have written a program to blink LED's in sequence which are connected to PORT B in PIC16F886. In MPLAB and the compiler is CCS. Hex is generated without any errors. But when i executed in hardware only one LED IS BLINKING. I want 1st LED to blink at 1 sec, second one at 1.5sec and third one at 2 sec.
I am using timer 0 as counter(8 bit). Please help me. Thanks in advance.
here is the program.
#define _LEGACY_HEADERS
#include <16F886.h>
#include <stdio.h>
#include <math.h>
#include <float.h>
//__CONFIG(FCMDIS & IESODIS & BORDIS & UNPROTECT & MCLRDIS & PWRTEN & WDTDIS & INTIO );
#define T0IF=0;
#define TOIE=1;
#define CMCON0 = 7; // disable compaarator
#define ANSEL = 0; // disable analog channel
#define PEIE = 1; // Enable peripherial interrupts and start processing
#define GIE = 1;
#define SYS_FREQ (8000000L) // System frequency
#define INTCON = 0;
#define TRISB= 00111000; //initialise the input and output terminals for PORT B
#define high_start 76; // high start used for timer0 overflow
int count;
void clock_isr();
count=0;
#define T0SE = 0; // falling edge selected
#define T0CS = 1; // Internal clock selected (timer mode ON)
#define PSA = 0; // Prescaler is assigned to the Timer0 module
#define TMR0ON = 1; // Turn ON the timer
#define T0PS0 = 1; // Prescalar values
#define T0PS1 = 1; // Prescalar values
#define T0PS2 = 1; // Prescalar values
output_bit(PIN_B0,0); //START_delay is OFF
output_bit(PIN_B1,0); //Integrator_delay is OFF
output_bit(PIN_B2,0); // soft_start_on is OFF
   clock_isr();
   // if count is 7812 decimal =1 sec / to put the hex value
   // in 16 bit,we need to initialise WDT timer
   if(count=7812) {
      output_bit(PIN_B0,1); //START_delay is ON
   else if(count=11718) // if count is 11,718 decimal =1.5 sec
      output_bit(PIN_B2,1); // soft_start_on is ON
   else if(count=15624) // if count is15,624 decimal =2 sec
      output_bit(PIN_B1,1); //Integrator_delay is ON
byte seconds, high_count;
#define INT_RTCC 0x000B20;  // Interrupt procedure
void clock_isr()
// called every time RTCC
high_count -= 1;  // flips from 255 to 0
if(high_count==0) {
   ++count;
   high_count=high_start;  // Inc SECONDS counter every
  }  // 76 times to keep time
PostPosted: Thu May 31, 2018 11:45 am     Reply with quote
Lots of things are fundamentally wrong:
#define T0IF=0;
#define TOIE=1;
#define GIE = 1;
#define INTCON = 0;
Each of these does basically nothing. In C a #define is a text substitution macro. Nothing else. So the third line for example defines a text macro called 'CMCON0', which if you type it into the code will be replaced with '= 7'. Since you never type it, nothing at all is done....
So, the timer is never turned on. No interrupts are enabled. TRIS is never set. etc. etc.
Then you define the variable 'count' as a int. A int can hold 0 to 255. So it is never going to get to get to 7812, let alone 11718....
Read some of the CCS examples, and some of the code here. Use the CCS instructions to set the features you want.
PostPosted: Thu May 31, 2018 12:11 pm     Reply with quote
void clock_isr()
Also, this is not how you tell the CCS compiler that clock_isr() is an RTCC
interrupt routine. Look in the CCS example file, Ex_dtmf.c. It shows
how to do it.
Another thing. You are placing a semi-colon (;) at the end of every
#define statement. This is not normally done in the C language.
You should stop doing it. It will cause compilation errors.
PostPosted: Thu May 31, 2018 12:27 pm     Reply with quote
The reason that hasn't given errors, is that since none of he defines is actually 'used', the substitution including the ; never actually takes place!.... Double ouch.
Roopa K
PostPosted: Sun Jun 03, 2018 11:28 pm     Reply with quote
HI,
Thank you for the reply. I will make the changes and i will try
Roopa K
PostPosted: Sun Jun 03, 2018 11:37 pm     Reply with quote
@Ttelmah
as Timer0 is also a 8 bit counter i have to use overflow flag setting. Is Count has to be defined as unsigned long int?
Roopa K
errors in modified program
PostPosted: Mon Jun 04, 2018 12:57 am     Reply with quote
I have changed my program according to suggestion. Now I am not using RTCC. In the new program i am facing some errors. Please help me to correct them.
following are the errors
>>> Warning 203 "led blinking.c" Line 36(1,1): Condition always TRUE
*** Error 58 "led blinking.c" Line 37(18,22): Expecting a close paren
*** Error 5 "led blinking.c" Line 54(12,13): Character constant constructed incorrectly
*** Error 49 "led blinking.c" Line 54(12,13): Expecting LVALUE such as a variable name or * expression
*** Error 5 "led blinking.c" Line 54(15,17): Character constant constructed incorrectly
*** Error 5 "led blinking.c" Line 55(16,17): Character constant constructed incorrectly
7 Errors, 1 Warnings.
The modified program is as follows
#include <16F886.h>
#include <stdio.h>
#include <math.h>
#include <float.h>
#define T0IF'=0'
#define TOIE '=1'
#define CMCON0 '= 7'                              // disable compaarator
#define ANSEL '= 0'                           // disable analog channel
#define  PEIE '= 1'                            // Enable peripherial interrupts and start processing
#define GIE '=1'
#define INTCON '= 0'
#define TRISB'= 00111000'                               //initialise the input and output terminals for PORT C
#define T0SE '= 1'             // falling edge selected
#define T0CS '= 0'          // Internal clock selected (timer mode ON)
#define PSA '= 0'             // Prescaler is assigned to the Timer0 module
#define TMR0ON '= 1'         // Turn ON the timer
#define T0PS0 '= 1'           // Prescalar values
#define T0PS1 '= 1'            // Prescalar values
#define T0PS2 '= 1'           // Prescalar values
void timercounter_ISR(void);             // function to increase  counter value
unsigned long count;
unsigned long high_count;
count=0;
   if(count==7812)                      // if count is 7812 decimal =1 sec      / to put the hex value in 16 bit,we need to initialise WDT timer
   else if(count==11718)                 // if count is 11,718 decimal =1.5 sec
   else if(count==15624)               // if count is15,624 decimal =2 sec
while(!T0IF'=0');
output_bit(T0IF,0);
count++;
Mike Walne
PostPosted: Mon Jun 04, 2018 2:54 am     Reply with quote
I've simply commented out all the lines which are causing errors.
I don't believe any of them are needed.
The program now compiles but not running as you expect.
(I don't have samples of your chip, but have run the code in MPLABSIM.)
For starters, you think you've set Timer to run, but it's not.
You are trying to set the registers with a load of #defines.
This is not the CCS way of doing things.
You need to look at some of the provided examples and learn from them.
Mike
PS Mr T. has also told you about the #defines. You have totally ignored his advice.
PostPosted: Mon Jun 04, 2018 4:51 am     Reply with quote
Knowledge is power !
You should look at several on the dozens of examples that CCS supplies, in the 'examples' folder. They will show you how to properly code in 'CCS style'.
Also if you press 'F11' while your project is open, the CCS manual will be shown on the screen, from there you can access a LOT of information CCS has including the FAQ section as well as links to some of the examples.
I understand English can be a very hard language to learn but a few hours reading the manual and most of it will make sense.
PostPosted: Mon Jun 04, 2018 6:03 am     Reply with quote
He is also doing a new sillie:
output_bit(T0IF,0);
Duh. You can't 'output' to an internal register.
It isn't an internal register anyway. It is currently the text '=0'.
AArgh.
