JAM2014
Sunrise & Sunset routine..... |
Posted: Tue Apr 03, 2018 8:39 am |
Hi All,
There is some code in the Code Library for calculating Sunrise and Sunset times based on current date & geographical (latitude/longitude) location. I took this code to create the module shown below, which I include in my main code. When I compile, however, I get a lot of errors.
One thing I'm unsure about is the #device ANSI statement. I don't want to do this, so I've commented it out and explicitly defined the required variables as signed or unsigned. Perhaps I'm missing something here?
Edit: This code has been updated so that is now compiles and works correctly!
Edit: A bug corrected that performed UT sanity checking before the UTC offset was applied. Corrected and tested.
#define ZENITH 90.833333333
float calc_suntime(signed int8 offset, int1 riseorset, int16 day, int16 month, int16 year, float lat, float lon)
//offset: offset to apply from UTC (in hours)
//riseorset: 1 for rise time, 0 for set time
float lngHour, Time, M, L, RA, Lquadrant, RAquadrant, sinDec;
float cosDec, cosH, H, T, UT, localT;
signed int16 N1, N2, N3, N;
N1 = floor(275 * month / 9);
N2 = floor((month + 9) / 12);
N3 = (1 + floor((year - 4 * floor(year / 4) + 2) / 3));
N = N1 - (N2 * N3) + day - 30;
lngHour = lon / 15;
if (riseorset)
//sunrise time
Time = N + ((6 - lngHour) / 24);
//sunset time
Time = N + ((18 - lngHour) / 24);
M = (0.9856 * Time) - 3.289;
L = M + (1.916 * sin((PI/180) * M)) + (0.020 * sin((PI/180) * 2 * M)) + 282.634;
//need to adjust L to be in range (0,360)
while ((L > 360) || (L < 0))
if (L > 360) L -= 360;
if (L < 0) L += 360;
RA = (180/PI) * atan(0.91764 * tan((PI/180) * L));
//need to adjust RA to be in range (0,360)
while ((RA > 360) || (RA < 0))
if (RA > 360) RA -= 360;
if (RA < 0) RA += 360;
Lquadrant = (floor( L/90)) * 90;
RAquadrant = (floor(RA/90)) * 90;
RA = RA + (Lquadrant - RAquadrant);
RA = RA / 15;
sinDec = 0.39782 * sin((PI/180) * L);
cosDec = cos((PI/180) * ((180/PI) * asin(sinDec)));
cosH = (cos((PI/180) * ZENITH) - (sinDec * sin((PI/180) * lat))) / (cosDec * cos((PI/180) * lat));
if (cosH > 1)
the sun never rises on this location (on the specified date)
if (cosH < -1)
the sun never sets on this location (on the specified date)
if (riseorset)
//sunrise time
H = 360 - ((180/PI) * acos(cosH));
//sunset time
H = (180/PI) * acos(cosH);
H = H / 15;
T = H + RA - (0.06571 * Time) - 6.622;
UT = T - lngHour;
localT = UT + offset;
//Here we do some sanity checking!
if(localT > 24)
localT -=24;
else if (localT < 0)
localT += 24;
return localT;
Here is my main program that uses the module code shown above:
#include <18F44K22.h>
#fuses INTRC_IO, NOWDT, PUT, NOLVP, NOPBADEN, FCMEN
#use delay(clock=8000000)
#include <math.h>
#include <suntime.c>
#define PWR_LED Pin_B1
#define Serial_TxD Pin_B4 // serial debug port
#use rs232(baud=9600, xmit=Serial_TxD, stream = Diag)
int8 iIndex;
//Sunrise & Sunset variables.....
float fSunRise = 0;
float fSunRiseHour = 0;
float fSunRiseMinute = 0;
unsigned int8 iSunRiseHour = 0;
unsigned int8 iSunRiseMinute = 0;
float fSunSet = 0;
float fSunSetHour = 0;
float fSunSetMinute = 0;
unsigned int8 iSunSetHour = 0;
unsigned int8 iSunSetMinute = 0;
// Here we turn off the Pwr LED
output_low(PWR_LED);
// Here we blip the Power LED at power-up to show that the Lighting interface is working
for ( iIndex = 0 ; iIndex < 3 ; iIndex++ )
output_high(PWR_LED);
delay_ms(250);
delay_ms(250);
// Here we leave the Power LED ON
delay_ms(3000);
//Here we calculate the current Sunrise and Sunset times.....
//Format: UTC Offset, Rise/Set, Day, Month, Year, Latitude, Longitude)
fSunRise = calc_suntime(-4, 1, 3, 4, 2018, 41.610717, -73.227455);
fSunSet = calc_suntime(-4, 0, 3, 4, 2018, 41.610717, -73.227455);
fSunRiseHour = floor(fSunRise);
iSunRiseHour = (int8)(fSunRiseHour);
fSunRiseMinute = (fSunRise - fSunRiseHour) * 60;
iSunRiseMinute = (int8)(fSunRiseMinute);
fSunSetHour = floor(fSunSet);
iSunSetHour = (int8)(fSunSetHour);
fSunSetMinute = (fSunSet - fSunSetHour) * 60;
iSunSetMinute = (int8)(fSunSetMinute);
fprintf(Diag, "\n\rSunrise: %02d:%02d\n\r", iSunRiseHour, iSunRiseMinute);
fprintf(Diag, "\n\rSunset: %02d:%02d\n\r", iSunSetHour, iSunSetMinute);
while(1){}
Thanks,
Jack
Joined: 01 Jul 2010 Posts: 9096 Location: Greensville,Ontario
Posted: Tue Apr 03, 2018 9:57 am |
Hay, I got it running NOW ! One of those..'interesting' things I was meaning to do...so chickens get more 'daylight'.
Anyway using ANSI does TWO things...
1) makes all variables SIGNED ( CCS default is UNsigned)
and
2) ENABLES 'CASE' so that names like 'Variablex' and 'VariableX' are NOT the same!
getting around #1 is easy. #2 was 'fun' for me as 'streams' didn't work..it was that CCS requires stream names to be ALL UPPER CASE.
I did have to make some code changes though as it got 'hung up' in this code...
while ((UT > 24) || (UT < 0))
if (UT > 360) UT -= 24;
if (UT < 0) UT += 24;
Just PM me if you want the code, it's been within a minute of 'official sunrise/set' numbers so I'm happy.
Gabriel
Posted: Tue Apr 03, 2018 10:50 am |
Jay, you got Chickens?
I got about 30 layers (and love them) and ive been thinking of automating the coop too!
Im liking this thread.
Posted: Tue Apr 03, 2018 10:57 am |
Quote: | Just PM me if you want the code
You always ask everybody else to post their code when they have it
working. Why now the secrecy ? |
Posted: Tue Apr 03, 2018 11:06 am |
// calculate sunrise or sunset function
float calc_suntime(int8 cst_oft, int1 riseorset, int16 cst_day, int16 cst_mth, int16 cst_yer, float lat, float lon)
//cst_oft: offset to apply from UTC (in hours)
float cst_lhr, cst_t, cst_m, cst_l, cst_ra, cst_lq, cst_rq, cst_sd;
float cst_cd, cst_ch, cst_h, cst_uh, localT,cst_t1;
int16 cst_n1, cst_n2, cst_n3, cst_n;
// check dst flag to properly compute sunrise/sunset times
if(dstflg==0)
cst_oft=-5;
cst_oft=-4;
cst_n1 = floor(275 * cst_mth / 9);
cst_n2 = floor((cst_mth + 9) / 12);
cst_n3 = (1 + floor((cst_yer - 4 * floor(cst_yer / 4) + 2) / 3));
cst_n = cst_n1 - (cst_n2 * cst_n3) + cst_day - 30;
cst_lhr = lon / 15;
if (riseorset)
cst_t = cst_n + ((6 - cst_lhr) / 24); //sunrise
cst_t = cst_n + ((18 - cst_lhr) / 24); //sunset
cst_m = (0.9856 * cst_t) - 3.289;
cst_l = cst_m + (1.916 * sin((PI/180) * cst_m)) + (0.020 * sin((PI/180) * 2 * cst_m)) + 282.634;
while ((cst_l > 360) || (cst_l < 0))
if (cst_l > 360) cst_l -= 360;
if (cst_l < 0) cst_l += 360;
cst_ra = (180/PI) * atan(0.91764 * tan((PI/180) * cst_l));
while ((cst_ra > 360) || (cst_ra < 0))
if (cst_ra > 360) cst_ra -= 360;
if (cst_ra < 0) cst_ra += 360;
cst_lq = (floor( cst_l/90)) * 90;
cst_rq = (floor(cst_ra/90)) * 90;
cst_ra = cst_ra + (cst_lq - cst_rq);
cst_ra = cst_ra / 15;
cst_sd = 0.39782 * sin((PI/180) * cst_l);
cst_cd = cos((PI/180) * ((180/PI) * asin(cst_sd)));
cst_ch = (cos((PI/180) * ZENITH) - (cst_sd * sin((PI/180) * lat))) / (cst_cd * cos((PI/180) * lat));
if (riseorset)
cst_h = 360 - ((180/PI) * acos(cst_ch)); //sunrise
cst_h = (180/PI) * acos(cst_ch); //sunset
cst_h = cst_h / 15;
cst_t1 = cst_h + cst_ra - (0.06571 * cst_t) - 6.622;
cst_uh = cst_t1 - cst_lhr;
if(cst_uh>24 )
cst_uh=cst_uh-24;
else if (cst_uh <0)
cst_uh=cst_uh+24;
localT = cst_uh + cst_oft;
return localT;
OK, it ain't C pretty, but it works. It's now a file I can '#include' into other programs.
I had to rename the variables as they conflicted with ones I already was using. cst stands for 'calculatesuntimes'. Also the last IF section I had to make, cause the original kept staying in the 'loop' forever.
BTW ANSI does two things, one makes variable default to signed AND enables #CASE, which means VariableA is NOT the same as variablea.
update:edit:sigh
this line, close to the end of the 'compute times function'..
else if (cst_uh <0)
does NOT work for April 13th ! Sunset comes back as -4:00, should be 20:00. change it to..
else if (cst_uh <2)
.. and it'll work for the rest of the year
I'm convinced it's a 'floating point vs conditional' fight, but after 4 days and 72 tries I finally got good code for the year. I sure hope the chickens will be happy !
JAM2014
Posted: Wed Apr 04, 2018 10:18 am |
Hi All,
Yes, the problem with the code was that there were two variables, 't' & 'T', that were suddenly the same without the #device ANSI statement. I renamed one of them, and now the code compiles and operates correctly.....
OK, now I'll mention that I really dislike float variables! Adding this module to my project totally chewed up my available ROM I looked at possibly converting the code to use scaled integers instead of floats, but I'm not sure the Trig. functions will allow that?
So, I guess I'm off to order some PIC's with larger Program memory available!
Jack |
alan
Joined: 12 Nov 2012 Posts: 349 Location: South Africa
Posted: Wed Apr 04, 2018 1:27 pm |
I've settled on the PIC18F46K22 DIP as my goto PIC. Yes way overkill for most projects but with 2 HW UARTS, 2 HW SSP, LOTS of memories and I/O pins my clients have yet to run out of 'stuff'. Yes, it may cost a few pennies more BUT by standardizing on this device I've made a large library of known, working code which saves a LOT of time..and well, time is money !
BTW there are other algorithms for computing sunrise/set but this one works. It may be worth your time to google about it.
JAM2014
Posted: Wed Apr 18, 2018 12:36 pm |
Hi All,
I further updated this code to correct a bug that occasionally yielded negative sunset times. The issue was that the sanity checking for the time (ie. <0 or >24) needs to be done after the UTC correction is applied. This has now been changed and tested.
Jack |
