Warning 230
SeeCwriter
Warning 230
PostPosted: Wed Nov 08, 2017 10:18 am     Reply with quote
I compiled an old program with v5.075 and I now get a warning about "String truncated" and I don't understand it.
#define MYSTRING  "some string"
void Func()
  char *p;
  p = MYSTRING;  // <-- WARNING 230: String truncated.
This is for an 18F87J60 with PCWHD v5.075.
PostPosted: Wed Nov 08, 2017 10:47 am     Reply with quote
void Func()
char *p;
I don't see how you think that can work. "some string" is just a bunch of
MOVLW's. It's not an array.
Look at the .LST file to see what's happening. It's just taking the first
two characters from "some string" and stuffing them into the 16-bit
pointer 'p'. That's not what you wanted.
.................... void Func()
.................... char *p;
.................... p = MYSTRING; // <-- WARNING 230: String truncated.
00004: MOVLW 73 // This is 's'
00006: MOVWF p
00008: MOVLW 6F // This is 'o'
0000A: MOVWF p+1
0000C: GOTO 002A (RETURN)
SeeCwriter
PostPosted: Wed Nov 08, 2017 11:05 am     Reply with quote
I should have looked at the listing. So why does using strcpy work? I don't see why they should work differently.
void Func()
   char str[16];
   strcpy( str, MYSTRING );
PostPosted: Wed Nov 08, 2017 11:29 am     Reply with quote
In the first program, there is no array. The compiler doesn't implicitly
create an array from the #define statement. There is no place for the
string to go.
In the 2nd example, strcpy() copies the constants from MYSTRING into a
RAM array that you declared.
