How to open ide preferences in order to configure IDE
jujoab
PostPosted: Tue Sep 19, 2017 10:20 pm     Reply with quote
I am searching for hours on this forum trying to find the way to have code completion or code assist working.
One note I found says to open the preferences tab but I can't find it.
Thanks in advance.
juan abba
PostPosted: Wed Sep 20, 2017 12:57 am     Reply with quote
Options.
IDE
Are you sure are looking at documentation for Custom Computer Services?.
Unfortunately a lot of web searches on 'CCS', instead find stuff relating to Ti Code Composer Studio (which is also abbreviated as 'CCS').
A reference to 'preferences', makes me think you are looking at 'webwork' for the Ti IDE, not the Custom Computer Services IDE...
Custom Computer Services C, doesn't have a 'code assist' option. Code completion is normally on by default.
CCS (here), predates Ti using the same initials, so 'blame Ti' for electing to use the same name....
jujoab
PostPosted: Wed Sep 20, 2017 7:13 am     Reply with quote
Thanks Ttelmah.
I assumed that they were the same ( ti and pic ) CCS c.
Pls let me ask for an extra piece of help.
My code completion did work OK, but now is not showing any completion when ctrl + space is pressed.
Just in case I reinstalled the 074, but still not working.
Is there anywhere on the IDE configuration the may affect code completion ????
jujoab
PostPosted: Wed Sep 20, 2017 2:55 pm     Reply with quote
Hi
I found the configuration windows were "USE CODE COMPLETE" could be selected.
OPTIONS-->>IDE-->>GENERAL-->>EDITOR options.
It was selected on my case, but as explained on previous note it was not working.
I deselected and selected again with no expected results.
Them I proceed with a complete deinstallation, even cleaning PICC folder and installed again.
Problem remains. CTRL + space do not produce any results.
Thanks in advance.
juan
PostPosted: Wed Sep 20, 2017 7:02 pm     Reply with quote
On the versions page they say:
5.074 Fixed an issue where code completion in the IDE would replace too much text.
Maybe they broke it instead.
If you own the compiler and paid for it, then contact CCS support.
Their email is: support@ccsinfo.com
jujoab
PostPosted: Thu Sep 21, 2017 1:56 pm     Reply with quote
There is a trick to get it working.
Tested several PIC's, all ok.
The trick is to create the project, insert a few lines after
#include <xxxxxxxxxx.h> and BUILD it.
After doing the build, the "code completion" will start to work for that project, even with 074.
Thanks for the help.
juan
