Warning 201 : Assignment inside relational expression
Ranfo
PostPosted: Tue Sep 12, 2017 9:02 am     Reply with quote
When I do this...
if ((mnum = com_delay(duration)) > 0) {
    // Do stuff with mnum
I get "Warning 201 : Assignment inside relational expression",
but it appears to work anyway. Should I be concerned?
Is it safe to ignore this warning with CCS?
PostPosted: Tue Sep 12, 2017 12:09 pm     Reply with quote
'Tis sloppy, and therefore, 'tis bad.
mnum = com_delay(duration);
if (mnum > 0) {
...'tis better.
PostPosted: Tue Sep 12, 2017 1:16 pm     Reply with quote
It's perfectly acceptable C.
It is just a warning. It is designed to remind you that a=b in a test, may not be what you want. Separating the assignment and the test ensures this does not happen, but in some cases results in slower code. YPYMATYC.
PostPosted: Tue Sep 12, 2017 2:00 pm     Reply with quote
Until you hit a performance wall (be that execution speed and/or code size) I'm of the belief that readable = preferable. I came to hold that belief after I inherited a project from a person who took perverse pleasure in jamming as many statements into a single line as he possibly could.
If the project will never be passed off to another soul, then by all means incorporate space saving shortcuts - if that's your thing.
Ranfo
PostPosted: Tue Sep 12, 2017 3:15 pm     Reply with quote
Ttelmah is correct. Not only acceptable, but common. Not sloppy or bad.
Some compilers will do stupid things when warnings are ignored, so that is why I asked. Also, I hate having compiler warnings.
Is is academic at this point because I discovered that I did not want to change the value mnum if the result is 0, so ended up with this:
v = com_delay(duration);
if (v > 0) {
    mnum = v;
alan
PostPosted: Wed Sep 13, 2017 12:58 am     Reply with quote
The above post actually proves newguy's point, by rewriting to get rid of warning you saw the flaw in your thinking.
PostPosted: Wed Sep 13, 2017 1:08 am     Reply with quote
It has to do with ones attitude. I always write code in the most simple
way I can (or I think I do), because I realize it will have to be maintained
later. If you don't care about the company you work for and its future,
then you might write code any old which-way.
PostPosted: Wed Sep 13, 2017 5:05 am     Reply with quote
re:
hehehe....
I used to do that 30 years ago, so 'guilty'.
When I did the coding , it looked 'fine' and I understood it. Now when I see it, I scratch my head and say 'what is this, who wrote this and what does it do, arrrrrrrrgh' !
'funny' thing is when I coded in assembler, EVERY line was commented, yet when I used BASIC , I got sloppy. Now I'm in the middle of the road, though the older I get the more I need those comments !
Where single line coding shines is FUSES ! I have a separate 'include' file just for fuses. One fuse on one line. I don't type great,so doing fuses ONCE is a good thing since there's more fuses than PIC instructions these dayze !!
