UART not working 18f25k22
ep.hobbyiest
PostPosted: Sat Sep 09, 2017 1:56 am     Reply with quote
I am using pic18f25k22 PIC. Code is working on proteus but not on real hardware.
Led blinking is working properly on hardware.
Here is the code.
#include <main.h>
      //TODO: User Code
      printf("Live\r\n");
and main.h file is as
#include <18F25K22.h>
#device ADC=16
#use delay(internal=16MHz)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=PORT1)
PostPosted: Sat Sep 09, 2017 4:58 am     Reply with quote
Normally you will not get too many responses with 'Proteus' related questions. See PIC101.
My guess is that you've assigned the UART to a 'stream' AND you don't tell 'printf' to use that 'stream', so the PIC doesn't send data to whatever is attached to the PIC's UART pins. Not too sure where it goes but the listing would say.
Whenever you have project open, press F11, and the CCS C manual will 'popup'! Then you can quickly search and read about the various features and functions and syntax.
As you just found out Proteus does NOT work properly !! Even for SIMPLE code, it FAILS.
ep.hobbyiest
PostPosted: Sat Sep 09, 2017 5:32 am     Reply with quote
Thanks. It worked. I checked the manual and i saw printf. So, i just use same printf function as normal stdio.h includes.
