isdigit unexpected behavior
E_Blue
PostPosted: Mon Sep 04, 2017 8:04 am     Reply with quote
I'm parsing a string separated by commas and some data is a float number but I don't need the decimal part so I'm filtering by using isdigit(x) function but that function return true when is a dot(.) and in the CCS help says:
isdigit(x) X is '0'..'9'
So there's any way to specify that only returns true to 0 to 9 ASCII codes?
Electric Blue
E_Blue
PostPosted: Mon Sep 04, 2017 8:18 am     Reply with quote
Never mind, my mistake, bad pointer.
Dummy=(*Punt_GGA[8]+x);
      if(isdigit(Dummy))
Corrected.
Dummy=(*(Punt_GGA[8]+x));
      if(isdigit(Dummy))
Electric Blue
PostPosted: Mon Sep 04, 2017 8:21 am     Reply with quote
Yes. Use 'isamong'.
The 'isamong' command is the 'parent' of the others.
So:
#define isdigitonly(x) isamong(x, "0123456789")
will give you a new operation 'isdigitonly', that behaves exactly like 'isdigit', except is only accepts the digit not the decimal.
isdigit, itself is only a similar macro expansion declared in ctype.h
E_Blue
PostPosted: Mon Sep 04, 2017 2:03 pm     Reply with quote
Thanks for your answer, I will take that in account.
Electric Blue
