Exit INT RTCC
art
Exit INT RTCC
PostPosted: Tue Aug 22, 2017 10:31 pm     Reply with quote
I'm trying to exit INT_RTCC when I push button B4, pin B5 will become low but it will not exit the interrupt. Hope anybody can show me how to solve it. Below is my code.
#include <18F4550.h>
#fuses HSPLL,NOWDT,PROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN          // not use due to project used <usb_bootloader.h>
#use delay(clock=48000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,ERRORS)
#include <string.h>
#include <input.c>
#include <stdio.h>
#include <stdlib.h>
#define INTS_PER_SECOND 9    //91     // (20000000/(4*4*65536))
#INT_RTCC                   // This function is called every time
void clock_isr()            // timer 1 overflows (65535->0), which is
{                           // approximately 19 times per second for
                            // this program.
int32 v;        // A running seconds counter
int8 int_count; // Number of interrupts left before a second has elapsed
if(--int_count==0)
   if(input(PIN_B4))  //if push button B4 ON
      ++v;
      int_count = INTS_PER_SECOND;
   else   //if push button B4 OFF
      output_low(PIN_B5);
      disable_interrupts(INT_RTCC);
int  r2, y;
int8 i;
int16 aa[16];
setup_timer_0(RTCC_DIV_2|RTCC_INTERNAL); // presacaler=2, Use EXTERNAL clock
                                         // if prescaler = 2, then every tick approximately = 0.167 Usecond
                                         // 4x2 / 48000000 = 0.167usecond
while(true)
   while(input(PIN_B4));  //wait push button B4 ON
   if(input(PIN_B0))
      output_high(PIN_B5);
   for(y=0; y<=200; y=y+8)
       printf("\r");
       set_timer0(0);
       enable_interrupts(INT_RTCC);
       v = 0;
       while (!input(PIN_B6));
       set_timer0(0); // init timer0 to 0
       delay_ms(220);
       while (input(PIN_B6));
       r2=1;
       for(i=2;i<=16;i++)
           while (!input(PIN_B6)); // wait for B6 to go LOW
           while (input(PIN_B6)); // wait for B6 to go HIGH
           aa[i]=get_timer0();
   output_low(PIN_B5);
alan
PostPosted: Wed Aug 23, 2017 1:05 am     Reply with quote
You have to declare int_count as static to preserve it between interrupts.
static int8 int_count= INTS_PER_SECOND;
otherwise the var gets destroyed every time you exit the interrupt.
When re-entering it will use a scratch value with some undetermined value in it.
art
PostPosted: Wed Aug 23, 2017 1:41 am     Reply with quote
Dear alan,
I've changed the code as you suggested.
static int8 int_count; // Number of interrupts left before a second has elapsed
    if(--int_count==0)
      ++v;
      output_low(PIN_B5);
It will give the same result, pin B5 will output LOW when I push button B4. However I want to make it when I push once more button B4, pin B5 will become output HIGH.
PostPosted: Wed Aug 23, 2017 2:24 am     Reply with quote
There is another oddity. You have a local variable called 'v' in the interrupt, which you increment, and then another local variable called 'v' in the main. Now you don't use it as yet (except to increment it in the interrupt), but assuming you want this to be a counter that is handled in the interrupt and then visible in the main, there needs to be a single global declaration of this if it is to ever work...
Now you have B5 being set low in two places, but the only thing that can set it high again, is if B4 is low, B0 is high, and B6, has gone high then low 16 times.
