Problem using "strncmp"
pilar
PostPosted: Thu Jul 13, 2017 8:59 am     Reply with quote
Hi
Hello, I'm trying to compare two char strings using "strncmp", but I can not get it to work properly. Someone could tell me what is my mistake..
Here is my code:
#include <18F4520.h>
#device PASS_STRINGS=IN_RAM
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT,NOSTVREN
#use delay(clock=20MHz)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)// RS232 Estándar
#include <stdlib.h>
#define LED             PIN_D0
#define ON                 output_high
#define OFF                output_low
int const maxLongBuffRX=42;
char bufferRX[maxLongBuffRX];
int indBufferRX=0x00;
char XCommand[maxLongBuffRX];
char flag_RptaCommand;
int i;
void Add_bufferRX(char c);
void SendATCommand( char *pCommandTX );
#int_rda
void serial_isr() {
  if(kbhit()){
    Add_bufferRX(getc());
   flag_RptaCommand = 1;
void Ini_buff_rec(void){
  int i;
  for(i=0;i<maxLongBuffRX;i++){
    bufferRX[i]=0x00;
  indBufferRX=0x00;
void Add_bufferRX(char c){
  switch(c){
    case 0x0D:
    case 0x0A:
    default:
      bufferRX[indBufferRX++]=c;
void SendATCommand( char *pCommandTX, char *pRXCommand ){
char *ptr;
   Ini_buff_rec();
   flag_RptaCommand = 0;
   printf ("%s",pCommandTX);
   putc('\r');
   while (   flag_RptaCommand == 0);
   //ptr=strstr(bufferRX,pRXCommand);
   if(strncmp(bufferRX,pRXCommand,strlen(pRXCommand))== 0)
      ON (LED);
      OFF (LED);
void main(){
   OFF(LED);
   enable_interrupts(INT_RDA);
   clear_interrupt(INT_RDA);
    SendATCommand("AT", "OK");
   delay_ms(200);
while (TRUE);
PostPosted: Thu Jul 13, 2017 9:09 am     Reply with quote
There is a basic problem that you don't really want to do the test until you have the entire reply.
Change your interrupt handler:
#int_rda
void serial_isr() {
  if(kbhit()){
  switch(c){
    case 0x0D:
      bufferRX[indBufferRX++]='\0';
      flag_RptaCommand = TRUE;
    case 0x0A:
    default:
This way the flag to say a command has been received, will only be set when the carriage return after the 'OK' is seen, not after just one character. You also then have a proper null terminated string, which currently you don't have.
