Pointer for a fprintf
Orcino
PostPosted: Thu Jul 06, 2017 6:18 am     Reply with quote
Hello everyone.
I did the following function, which sends AT commands to a GPRS module and waits for response or timeout.
There are some guts going on and I'm suspecting the pointers that are passed to this function.
Can anyone tell if something is wrong with this function?
#include <24FJ128GB204.h>
#build (stack=512)
#device PASS_STRINGS=IN_RAM
sendComandoAT("AT+SAPBR=2,1","+SAPBR:",3000);
unsigned int8 sendComandoAT ( char *pCmdAT, char *pAnswer, int16 timeWait)
int8 nCaracter=0;
char *ptr;
nCaracter = strlen(pAnswer);
fprintf(GPRS,"%s\r",pCmdAT);
while( (GPRS_DataPtr < nCaracter + 4 ) && (++ timeOutRx < timeWait) )
       delay_ms(1);
ptr=strstr(bufferRxMsgGPRS,pAnswer);
      if(strncmp(ptr,pAnswer,nCaracter)==0)
         clearBuffer();
         timeOutRx=0;
         GPRS_DataPtr=0;
         return true;
         clearBuffer();
         timeOutRx=0;
         GPRS_DataPtr=0;
         return false;
PostPosted: Thu Jul 06, 2017 8:10 am     Reply with quote
AT+SAPBR=2,1, doesn't return +SAPBR: straight away. It returns OK first, then the +SABPR line a little later. Depending how your input function works, the strncmp, Won't return '0' if the leading 'OK\r' is there.
Orcino
PostPosted: Mon Jul 10, 2017 11:39 am     Reply with quote
That's right.
Thank you Ttelmah.
