Problem using printf to print string variables
BrunoC12
PostPosted: Thu May 25, 2017 7:56 pm     Reply with quote
I am using strtok to separate any string. Then, I save the different values in a string variable. Up to this point the program is fine.
After that, I print all the values but I can not see that. The program prints three of the four values.
I'll pass the code, any opinions will be very helpful. Thanks
#include <string.h>
#include <stdio.h>
char ID[], ST[], OR[], AK[];
   char string[30], term[4], *ptr;
   int i;
strcpy(string,"one,two,three,four");
strcpy(term,",;");
i=0;
ptr = strtok(string, term);
while(ptr!=0) {
  i++;
  puts(ptr);
   if(i==1)ID=ptr;
   if(i==2)ST=ptr;
   if(i==3)OR=ptr;
   if(i==4)AK=ptr;
   ptr = strtok(0, term);
    i=0;
   printf("%s \n\r %s \n\r  %s \n\r %s \n\r ",ID, ST, OR, AK);
PostPosted: Fri May 26, 2017 1:12 am     Reply with quote
It works for me in MPLAB vs. 8.92 simulator with vs. 5.071. Of course, I
put a while(TRUE) at the end of the program, to prevent it from going
to sleep while it's still transmitting characters. Here is the output:
one
two
three
four
one
two
three
four
If it still doesn't work after you add a while(TRUE) statement at the end
of main(), then post a compilable test program, similar to what is shown
below:
#include <18F46K22.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOPBADEN
#use delay(clock=4M)
#include <string.h>
#include <stdio.h>
int i;
strcpy(term,",;");
i=0;
while(ptr!=0)
   i++;
   puts(ptr);
   if(i==1)ID=ptr;
   if(i==2)ST=ptr;
   if(i==3)OR=ptr;
   if(i==4)AK=ptr;
i=0;
printf("%s\r%s\r%s\r%s\r", ID, ST, OR, AK);
while(TRUE);  // Prevent PIC from going to sleep
PostPosted: Fri May 26, 2017 7:03 am     Reply with quote
He launched two separate threads at the same time about this....
PostPosted: Fri May 26, 2017 7:33 am     Reply with quote
Yes, I saw that. We posted only 3 minutes apart, and your post wasn't
visible to me at the time I posted.
PostPosted: Fri May 26, 2017 10:32 am     Reply with quote
Happens... Smile
Usually, one starts to reply and by the time one has typed the reply another answer has appeared!...
Perhaps one of the moderators could 'units' the threads?.
BrunoC12
PostPosted: Fri May 26, 2017 10:43 am     Reply with quote
I tried with while(true), but the program send the same answer.
one
two
three
four
one
two
three
I think the problem is that it doesn't save the last data in the variable AK because it prints an empty space at the end, but I do not know why
PostPosted: Fri May 26, 2017 11:03 am     Reply with quote
If you read my post, I said:
of main(), then post a compilable test program, similar to what is shown below:
#include <string.h>
#include <stdio.h>
etc.
Also post your compiler version.
BrunoC12
PostPosted: Fri May 26, 2017 1:38 pm     Reply with quote
Oh, sorry, I had not considered it. With that code the program works correctly, but I need to do it with the 16F628a.
I'm going to try MPLAB to see if it works.
Thanks for your help.
By the way, I use PCWHD Compiler Version 5.015.
PostPosted: Sat May 27, 2017 12:58 am     Reply with quote
So, post us the code that doesn't work in the 628A.
Your original code doesn't show the processor stuff. PCM_programmer has posted code that works, so now show us similar code that doesn't.
I've taken PCM_Programmer's code, changed the header to:
#include <16F628A.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOMCLR //no MCLR needed for my board
#use delay(internal=4M)
and it runs fine on a 628A. Prints:
one
two
three
four
on hyperterminal.
and just amended to say that the test was with 5.015.
