18F26K22 Two Hardware UARTS - RS485
jjacob
PostPosted: Tue Apr 04, 2017 12:43 pm     Reply with quote
I'm trying to implement a RS485 converter. I have a MASTER serial device that sends data to my converter, then converter sends to rs485 network. If convert receives something from rs485 network then sends to serial device.
#include <18F26K22.h>
#device adc=10
#FUSES INTRC_IO        // INTRC_IO Internal RC Osc, no CLKOUT
#FUSES NOFCMEN         //Fail-safe clock monitor disabled
#FUSES NOIESO          //Internal External Switch Over mode disabled
#FUSES NOPUT            //No Power Up Timer
#FUSES NOBROWNOUT       //No brownout reset
#FUSES NOWDT            //No Watch Dog Timer
#FUSES NOPBADEN        //PORTB pins are configured as digital I/O on RESET
#FUSES NOMCLR          //Master Clear pin NOT enabled
#FUSES NOLVP           //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOXINST         //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES NODEBUG         //No Debug mode for ICD
#use    delay(clock = 16000000)
#define INIT_UART_BAUDRATE   9600
#use rs232(UART1, baud=INIT_UART_BAUDRATE, stream=rf, xmit=PIN_C6,rcv=PIN_C7, errors)
#use rs232(UART2, baud=INIT_UART_BAUDRATE, stream=rede, ENABLE = PIN_B5 , xmit=PIN_B6,rcv=PIN_B7, errors)
#define BUFFER_SIZE_A 32
BYTE buffer_A[BUFFER_SIZE_A];
BYTE next_in_A = 0;
BYTE next_out_A = 0;
#define BUFFER_SIZE_B 32
BYTE buffer_B[BUFFER_SIZE_B];
BYTE next_in_B = 0;
BYTE next_out_B = 0;
#INT_RDA
void serial_isr() {
    int t;
    buffer_A[next_in_A] = fgetc(rf);
    t = next_in_A;
    next_in_A = (next_in_A + 1) % BUFFER_SIZE_A;
    if (next_in_A == next_out_A)
        next_in_A = t; // Buffer full !!
#define bkbhit_A (next_in_A!=next_out_A)
BYTE bgetc_A() {
    BYTE c;
    while (!bkbhit_A);
    c = buffer_A[next_out_A];
    next_out_A = (next_out_A + 1) % BUFFER_SIZE_A;
    return (c);
#INT_RDA2
void serial_isr2() {
    int t;
    buffer_B[next_in_B] = fgetc(rede);
    t = next_in_B;
    next_in_B = (next_in_B + 1) % BUFFER_SIZE_B;
    if (next_in_B == next_out_B)
        next_in_B = t; // Buffer full !!
#define bkbhit_B (next_in_B!=next_out_B)
BYTE bgetc_B() {
    BYTE c;
    while (!bkbhit_B);
    c = buffer_B[next_out_B];
    next_out_B = (next_out_B + 1) % BUFFER_SIZE_B;
    return (c);
    enable_interrupts(INT_RDA2 | INT_RDA);
    printf("\r\n\Running...\r\n");
    // The program will delay for 10 seconds and then display
    // any data that came in during the 10 second delay
    do {
        while (bkbhit_A)
            fputc(bgetc_A(), rede);
        while (bkbhit_B)
            fputc(bgetc_B(), rf);
    } while (TRUE);
It works with only one of uart. With two simultaneous don't work. What I'm doing wrong?
Thanks for the help.
PostPosted: Tue Apr 04, 2017 12:53 pm     Reply with quote
this ?
I don't think is 'legal'. At least I've always only used one device per enable_interrupt.
I'd have to check on the eng PC to confirm but I do know the 46K22 will run 2 HW UARTs at 921600 for days without a hiccup !
PostPosted: Tue Apr 04, 2017 1:07 pm     Reply with quote
It's not legal. The OP will have to call them like:
enable_interrupts(INT_RDA);
enable_interrupts(INT_RDA2);
The only time I've seen a bitwise OR used for enable_interrupts() is for Change Notification interrupts, but there is still a specific way to do it.
PostPosted: Tue Apr 04, 2017 1:58 pm     Reply with quote
Also, general comments:
Far safer to use:
#use delay(INTERNAL=16MHz)
This ensures the clock is correctly programmed for 16Mhz.
You also don't need to specify the pins, if you use 'UART1' or 'UART2'. These are equivalent (for UART1) to
xmit=PIN_C6, rcv=PIN_C7, FORCE_HW
so it is rather silly to put the pin names as well...
jjacob
PostPosted: Wed Apr 05, 2017 4:07 am     Reply with quote
Thank you all for your help. It's solved.
It was the:
