Specific code
id31
Specific code
PostPosted: Sun Apr 02, 2017 2:27 am     Reply with quote
Hi all,
Is there a document that show the full code of
Spi write
Spi read
Write eeprom
Read eeprom
PostPosted: Sun Apr 02, 2017 5:36 am     Reply with quote
Compile the functions.
Look at the .lst file.
Shows the assembler used for the functions.
There is not actually a 1:1 answer, since the code will vary, according to what eeprom hardware the chip has, and which spi port is being used, (and if using spi_xfer, how many bytes are being sent, and whether hardware/software spi is being used).
PostPosted: Sun Apr 02, 2017 6:27 am     Reply with quote
Mr. T is 100% correct ! CCS does not 'hide' anything. As he said , cut code/compile/ dump listing. It's ALL there for you to see.
PostPosted: Sun Apr 02, 2017 6:48 am     Reply with quote
By default they do hide some stuff....
Not 'to be awkward', but so the listing is only of _your_ code, to simplify debugging. So core functions like the maths are not shown, unless you remark out the #NOLIST line at the start of the processor include file.
However do this, and set the project options to generate symbolic listings, and you even get the registers 'named' for you. Very Happy
The functions though are much more complex than you may expect. They are almost invariably massively 'overloaded', so several different versions depending on a whole variety of parameters. Only the one that applies to your source, will be included in the final code.
