jamalavedra
| pin RB5 output problem |
Posted: Fri Mar 03, 2017 12:31 pm |
I am using a 18LF2685 PIC and recently I have tried to turn on some LEDs with the pin RB5 with pin number 26. When trying with some other pins I get no problems but with this one I can't get it to high level. I have checked in the datasheet and it should apparently work because it is a TTL I/O digital pin. Any idea on what should I do to fix this?
thanks
jaume |
Posted: Fri Mar 03, 2017 12:39 pm |
I checked the datasheet..
RB5, 26, is also used for programming so if you have the PIC still connected to your programmer, it won't operate properly.
jamalavedra
Posted: Fri Mar 03, 2017 12:56 pm |
I've tried by disconnecting the programmer and still doesn't get to the high level. Other pins do work. I also tried by changing to some other 18LF2685 so the error is not in the PIC.
thanks
jaume |
Posted: Fri Mar 03, 2017 1:36 pm |
time to show us your test program.
it might be you have LVP fuse enabled and that will override RB5 to become an output.
jamalavedra
Posted: Fri Mar 03, 2017 1:40 pm |
this is how my fuses are defined
#include <18F2685.h>
#FUSES INTRC_IO //Low power osc < 200 khz
#FUSES NOBROWNOUT //Reset when brownout detected
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES BBSIZ4K //4K words Boot Block size
#FUSES NOMCLR //Master Clear pin enabled
#FUSES NOXINST //Extended set extension and Indexed Addressing mode enabled
#use delay(internal=8M)
regarding the void main there's only the output_high(pin_B5); so no much to be shown .
thanks
jaume |
Posted: Fri Mar 03, 2017 2:22 pm |
this is probably the problem...
Please check table 10-3 port b I/O summary, page 135. It says that enabling LVP disables digital output.
Posted: Sat Mar 04, 2017 1:38 am |
and understand that you almost certainly do not want LVP.
All normal programmers do not use this. Pretty much the only time you use LVP is if you have some other chip on the board that directly programs the PIC. |
jamalavedra
Posted: Sat Mar 04, 2017 6:22 am |
Thanks,
By disabling the fuse LVP works perfectly
jaume |
