Strange MPSIM for LATB & PORTB with PIC18F26K22 [SOLVED]
Mike Walne
PostPosted: Mon Feb 27, 2017 11:55 am     Reply with quote
Is this a known MPLAB SIM problem, or am I missing something?
I'm wanting to drive a stepper motor and started from the CCS example.
When I simulated in MPLAB for a PIC18F26K22 I got rubbish with CCS code.
I've played with the code and still get gibberish with the '26' device.
MPLAB is fine with PIC18F46K22 and PIC18F252 parts.
The real thing behaves as expected.
I've used the code below. On each line I've shown both '26' '46' outputs after the first time round.
I'm showing the states before execution of the instruction, i.e. where the cursor is pointing.
I'm using MPLAB IDE v8.92 and CCS v5.059
The disassembly listing for both '*K22' parts more or less agree.
// Port B Test
#include <18F26K22.h>
//#include <18F46K22.h>
#fuses ECH,NOWDT,NOPROTECT,NOLVP,NOPLLEN
//#include <18F252.h>
//#fuses HS,NOWDT,NOPROTECT,NOLVP
main()
   while (TRUE)               // PIC18F26K22     PIC18F46k22
   {                          // LATB   PORTB    LATB   PORTB
      output_low(PIN_B3);     // 0b0000 0b0111   0b1000 0b1000
      output_high(PIN_B0);    // 0b0111 0b0000   0b0000 0b0000
      output_low(PIN_B0);     // 0b0000 0b0111   0b0100 0b0100
      output_high(PIN_B1);    // 0b0111 0b0000   0b0000 0b0000
      output_low(PIN_B1);     // 0b0000 0b0111   0b0010 0b0010
      output_high(PIN_B2);    // 0b0111 0b0000   0b0000 0b0000
      output_low(PIN_B2);     // 0b0000 0b0111   0b0001 0b0001
      output_high(PIN_B3);    // 0b0111 0b0000   0b0000 0b0000
Disassembly listing looks OK to me.
1:                 // Port B Test
  0000    EF02     GOTO 0x4
2:
3:                 #include <18F26K22.h>
4:                 //#include <18F46K22.h>
5:                 #fuses ECH,NOWDT,NOPROTECT,NOLVP,NOPLLEN
6:                 //#include <18F252.h>
7:                 //#fuses HS,NOWDT,NOPROTECT,NOLVP
8:                 #use delay(clock=4000000)
9:
10:                main()
  0004    6AF8     CLRF 0xff8, ACCESS
  0006    9ED0     BCF 0xfd0, 0x7, ACCESS
  0008    010F     MOVLB 0xf
  000A    6B38     CLRF 0x38, BANKED
  000C    6B39     CLRF 0x39, BANKED
  000E    6B3A     CLRF 0x3a, BANKED
  0010    6A77     CLRF 0xf77, ACCESS
  0012    6A78     CLRF 0xf78, ACCESS
  0014    6A79     CLRF 0xf79, ACCESS
11:                {
12:                   while (TRUE)
13:                   {
14:                      output_low(PIN_B3);
  0016    9693     BCF 0xf93, 0x3, ACCESS
  0018    968A     BCF 0xf8a, 0x3, ACCESS
15:                      output_high(PIN_B0);
  001A    9093     BCF 0xf93, 0, ACCESS
  001C    808A     BSF 0xf8a, 0, ACCESS
16:                      output_low(PIN_B0);
  001E    9093     BCF 0xf93, 0, ACCESS
  0020    908A     BCF 0xf8a, 0, ACCESS
17:                      output_high(PIN_B1);
  0022    9293     BCF 0xf93, 0x1, ACCESS
  0024    828A     BSF 0xf8a, 0x1, ACCESS
18:                      output_low(PIN_B1);
  0026    9293     BCF 0xf93, 0x1, ACCESS
  0028    928A     BCF 0xf8a, 0x1, ACCESS
19:                      output_high(PIN_B2);
  002A    9493     BCF 0xf93, 0x2, ACCESS
  002C    848A     BSF 0xf8a, 0x2, ACCESS
20:                      output_low(PIN_B2);
  002E    9493     BCF 0xf93, 0x2, ACCESS
  0030    948A     BCF 0xf8a, 0x2, ACCESS
21:                      output_high(PIN_B3);
  0032    9693     BCF 0xf93, 0x3, ACCESS
  0034    868A     BSF 0xf8a, 0x3, ACCESS
  0036    D7EF     BRA 0x16
22:                   }
23:                }
24:                /*
  0038    0003     SLEEP
Does anyone else get the same as I do?
PostPosted: Mon Feb 27, 2017 1:24 pm     Reply with quote
What exactly is rubbish ? and where are you looking in MPLAB 8.92
when you see it. Give precise instructions on how to duplicate the
problem.
PostPosted: Mon Feb 27, 2017 1:52 pm     Reply with quote
The problem you have is the ECCP.
On the smaller PIC ECCP1 is multiplexed onto the low PortB pins.
The ECCP is designed so that it wakes up driving it's pins, so that a power driver using it, does not have it's inputs floating.
You need to turn off the ECCP so that the pins can be used for normal I/O.
Currently B0, is behaving as the ECCP fault control, so overrides the other pins....
PostPosted: Mon Feb 27, 2017 2:00 pm     Reply with quote
Thank you Ttelmah. I understand now. I never simulate i/o ports.
I only simulate code. That's why I didn't understand his question.
PostPosted: Mon Feb 27, 2017 2:43 pm     Reply with quote
The great thing is how good the 'team' here is. You'll spot oddities it'd take me ages to see, while I then see other things. Add a few others (Jay etc.), and there is little we don't know about the PIC. Smile
Mike Walne
PostPosted: Mon Feb 27, 2017 6:04 pm     Reply with quote
problem.
I'm looking at LATB and PORTB in a watch window as I single step through either the CCS source code or the disassembly listing.
The values I've added to the source code were copied from the watch window.
What's really throwing me is the fact that the hardware behaves perfectly with all the chips mentioned but the 18K26K22 does not tally with MPLAB SIM.
Thanks for your response.
Mike
Mike Walne
PostPosted: Mon Feb 27, 2017 6:18 pm     Reply with quote
Thanks Ttelmah. I sort of follow what you're telling me. My code is now
// Port B Test
main()
   setup_ccp1(CCP_OFF);
I still get the same output as before from MPLAB SIM.
Is there something else I have to do?
What am I missing when the hardware behaves as I expect?
Mike
PostPosted: Mon Feb 27, 2017 8:36 pm     Reply with quote
There is a bug with MPSIM and the 18F26K22. Read the yellow post by
dan1138 on the Microchip forum:
http://www.microchip.com/forums/m603514.aspx
He says you have to set ADCON1 to 0x0F to fix it. I did that. It works.
Try it.
// Port B Test
#byte ADCON1 = getenv("SFR:ADCON1")
ADCON1 = 0x0F;
Mike Walne
PostPosted: Tue Feb 28, 2017 3:46 am     Reply with quote
Yes, it works OK for me now.
I've just tried stepping through my original code in the MPLAB debugger. It operates correctly.
I suppose that's because MPLAB is reading the registers in the chip rather than simulating.
I'll add solved to the title, and hope it helps someone else.
I'm relieved to know that I wasn't losing my marbles.
I would probably have never found the fix on my own.
Thank you PCM.
Mike
I'm new to the *K22 chips, and was alerted to the problem when I adapted the CCS stepper motor code.
I was uncertain, for some time, whether the problem was CCS or MPLAB.
It seemed odd that Microchip could get something so basic so badly wrong.
Really pleased to have it solved, as I was wary of continuing to trust MPLAB.
