array to long conversion
ashrafkhatri
PostPosted: Mon Feb 27, 2017 1:37 am     Reply with quote
Hi;
I am getting currect data from serial port and i save it in array of 3.
i.e:
int array_display[3];
now i want to convert it to long int.
array_display[0] will be save on unit place of long int
array_display[1] will be save on ten place of long int &
array_display[2] will be save on hundred place of long int
Example:
if array_display[0] = 3 , array_display[1] = 4 & array_display[2] = 5 then
long int new_data should be 543.
& i used the following formula but it is not working.
new_data = array_display[0] + array_display[1]*10 + array_display[2]*100;
what is wrong with the method. Any Idea?
PostPosted: Mon Feb 27, 2017 1:58 am     Reply with quote
Critical change:
new_data = array_display[0] + array_display[1]*10 + array_display[2]*100L;
Note the 'L'.
Problem is that each 'array_display' value is an int8. '100' is also an int8. 5*100 using int8 maths, overflows and gives you 244.
Only the 'hundreds' can overflow this way (9*10 = 90 is still small enough to fit in an int8). Adding the 'L' makes the constant '100', into a 'long' (int16). So int16 arithmetic is then used here. Because int16 is then being used here the additions are also then done using int16, so it should then work.
ashrafkhatri
PostPosted: Mon Feb 27, 2017 3:15 am     Reply with quote
Thanks;
Code is now working
