PSMC configuration
dragonerd1
PSMC configuration
PostPosted: Wed Feb 22, 2017 1:03 pm     Reply with quote
I use PSMC for frequency variation. I use 32Mhz clock (8Mhx*4PLL).
setup_psmc(1, PSMC_VARIABLE_FREQ, PSMC_EVENT_TIME | PSMC_SOURCE_FOSC | PSMC_DIV_8, us(usPeriodo), PSMC_EVENT_TIME, us(100), PSMC_EVENT_TIME, us(350));
In this line I configure PSMC_SOURCE_FOSC, I think it's 32Mhz. If I use PSMC_DIV_8, the frequency is 4Mhz. But the system still behaves as if it were configured at 32Mhz.
Why?
The code is not right?
PostPosted: Wed Feb 22, 2017 2:59 pm     Reply with quote
And what is that behavior ?
PostPosted: Wed Feb 22, 2017 3:36 pm     Reply with quote
and what chip/compiler version?.
PostPosted: Wed Feb 22, 2017 3:42 pm     Reply with quote
Also...does a 1Hz LED program run correctly ?
PostPosted: Thu Feb 23, 2017 3:10 am     Reply with quote
You do realise that if you change the clock being used, you have to change the clock figure in the us define, to get it to do the calculations correctly?.
#define us(time)  (int16)(time*(getenv("CLOCK")/1000000))
This is assuming that the psmc is fed with the 'clock' (FOSC). To make these calculations work right if using FOSC/8, you have to change this define to match the clock being used.
