16F874A and 24C64 problem with writting 1800-1FFF
Bieli
PostPosted: Sun Jun 15, 2003 4:46 am     Reply with quote
PCM 3.091
16F874 + Atmel 24C64
I can't write data between address 1800-1FFF. On lower addresses 0000-17FF it work fine but higher not. Read function work, I can read data on this area, but I can't change it. I second 24C64 chip and it has this same.
#include <16f874a.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT
#define I2C_SDA PIN_C4
#define I2C_SCL PIN_C3
#use i2c(master,sda=I2C_SDA, scl=I2C_SCL)
#include <input.c>
void init_ext_eeprom() {
output_float(I2C_SCL);
output_float(I2C_SDA);
void write_ext_eeprom(long int address, byte data)
i2c_start();
i2c_write(0xa2);
i2c_write(address>>8);
i2c_write(address);
i2c_write(data);
i2c_stop();
delay_ms(10);
byte read_ext_eeprom(long int address)
byte data;
i2c_start();
i2c_write(0xa2);
i2c_write(address);
i2c_start();
i2c_write(0xa3);
data=i2c_read(0);
i2c_stop();
return(data);
main()
{byte value,cmd;
long address;
init_ext_eeprom();
{ do
{ printf("\r\nRead or Write: ");
cmd=getc();
cmd=toupper(cmd);
putc(cmd);
} while ( (cmd!='R') && (cmd!='W') );
printf("\n\rLocation: ");
address = gethex();
address = (address<<8)+gethex();
if(cmd=='R')
printf("\r\nValue: \%X\r\n",READ_EXT_EEPROM( address ) );
if(cmd=='W')
{ printf("\r\nNew value: ");
value = gethex();
printf("\n\r");
WRITE_EXT_EEPROM( address, value );
Bieli
Original Post ID: 144515255
Tomi
Re: 16F874A and 24C64 problem with writting 1800-1FFF
PostPosted: Sun Jun 15, 2003 8:55 am     Reply with quote
I didn't use 24C64 in the last two years but as I remember this chip has a "block write protect" feature and the default page is somewhere in the upper address space. Check the datasheet.
:=PCM 3.091
:=16F874 + Atmel 24C64
:=I can't write data between address 1800-1FFF. On lower addresses 0000-17FF it work fine but higher not. Read function work, I can read data on this area, but I can't change it. I second 24C64 chip and it has this same.
:=#include <16f874a.h>
:=#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT
:=#use delay(clock=4000000)
:=#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
:=#define I2C_SDA PIN_C4
:=#define I2C_SCL PIN_C3
:=#use i2c(master,sda=I2C_SDA, scl=I2C_SCL)
:=#include <input.c>
:=void init_ext_eeprom() {
:= output_float(I2C_SCL);
:= output_float(I2C_SDA);
:=void write_ext_eeprom(long int address, byte data)
:= i2c_start();
:= i2c_write(0xa2);
:= i2c_write(address>>8);
:= i2c_write(address);
:= i2c_write(data);
:= i2c_stop();
:= delay_ms(10);
:=byte read_ext_eeprom(long int address)
:= byte data;
:= i2c_start();
:= i2c_write(0xa2);
:= i2c_start();
:= i2c_write(0xa3);
:= data=i2c_read(0);
:= i2c_stop();
:= return(data);
:=main()
:={byte value,cmd;
:=long address;
:= init_ext_eeprom();
:=while(1)
:={ do
:= { printf("\r\nRead or Write: ");
:= cmd=getc();
:= cmd=toupper(cmd);
:= putc(cmd);
:= } while ( (cmd!='R') && (cmd!='W') );
:= printf("\n\rLocation: ");
:= address = gethex();
:= address = (address<<8)+gethex();
:= if(cmd=='R')
:= printf("\r\nValue: \%X\r\n",READ_EXT_EEPROM( address ) );
:= if(cmd=='W')
:= { printf("\r\nNew value: ");
:= value = gethex();
:= printf("\n\r");
:= WRITE_EXT_EEPROM( address, value );
:=Bieli
Original Post ID: 144515258
Felix Althaus
PostPosted: Sun Jun 15, 2003 9:22 am     Reply with quote
Hello
From the datasheet:
WRITE PROTECT (WP): The write protect input, when tied to GND, allows normal write operations. When WP is tied high to VCC, all write operations to the upper quandrant (8/16K bits) of memory are inhibited. If left unconnected, WP is internally pulled down to GND.
mfg
Felix
Original Post ID: 144515259
