lcd Function...i need a little tip
marcoelmejor
PostPosted: Thu Jan 19, 2017 11:36 am     Reply with quote
(my english is bad)
I'm just trying to do a function to show
letter by letter, just writing ("the sentence", delay time) in the function
but appears an error:
- attempt to create a pointer to a constant Crying or Very sad
Below is the indication where is the compiler error:
#include <16f877a.h>
#include <stdio.h>
#include <string.h>
#fuses xt,nowdt,put,nobrownout,nocpd
#define LCD_DB4   PIN_B2
#define LCD_DB5   PIN_B3
#define LCD_DB6   PIN_B4
#define LCD_DB7   PIN_B5
#define LCD_RS    PIN_D3
#define LCD_RW    PIN_D2
#define LCD_E     PIN_B1
#include <lcd1.c>
#define ms delay_ms
void des(char f[],long t);
   des("jojos", 500); // HERE: Attempt to create a pointer to a constant.
   ms(300);
void des(char f[], long t)
{ //funcion (frase a desplazar:letras, tiempo de retardo por letra: tiempo)
int y=1;//posicion y lcd
int x=1;//posicion x lcd
for(int i=1; i<sizeof(f); i++) //bucle for para colocar letra por letra
   lcd_gotoxy(x,y); //posicion lcd
   lcd_putc(f[i-1]); //que letra se colocara
   ms(t);//retardo por letra, dato introducido desde la funcion desplazar
   x++;//aumento posicion "X" del lcd
   if((x>16)&&(y==1))
     {//si la posicion "X" alcanza los 16 cuadros que continue la frase desde x=1,y=2
      y=2;
      x=1;
   if((x>16)&&(y==2))//Si alcanza los 16 cuadros de arriba y abajo, que  limpie lcd y continue escribiendo desde x=1,y=1
     lcd_putc("\f");
     x=1;
     y=1;
   if(i==sizeof(f)-1)//que limpie lcd cuando termine la frase y vuelva a comenzar
     lcd_putc("\f");
PostPosted: Thu Jan 19, 2017 11:53 am     Reply with quote
Try searching the forum.
This has been explained hundreds of times, as have the fixes.
PostPosted: Thu Jan 19, 2017 6:27 pm     Reply with quote
The answer is to add the line in bold below, just after the #include line:
#device PASS_STRINGS=IN_RAM
#include <stdio.h>
#include <string.h>
Ttelmah, I tried searching for "attempt to create a pointer to a constant"
with CCS and Google and it's not that easy to find the accurate answer,
and I even know what I'm looking for. The CCS search engine ignores
quoted strings and just searches on individual words.
If you use Google, the very first one that comes up has a long disertation
by you, but not the simple answer. Other Google responses in the same
list for the 1st one, are also not giving the short, simple answer.
Edit: He has informed me in a PM that this fixed his compilation problem.
PostPosted: Thu Jan 19, 2017 8:47 pm     Reply with quote
Unrelated but:
your "sizeof(f)" isn't going to work out very well in that function. It'll just return the size of a pointer to your array, not the size of the array itself. Even though you specify it as an array in the function params, it is actually passed as a pointer under the hood, so that is what the sizeof() will measure.
PostPosted: Fri Jan 20, 2017 12:30 am     Reply with quote
'Search for all terms' only gives one page of answers, and over half of these have pointers to others. I hoped he would look, because rather than giving the 'modern' answer (PASS_STRINGS), it would also give the explanations of 'why', and the other solutions, which may be better in some cases.
marcoelmejor
PostPosted: Fri Jan 20, 2017 7:56 pm     Reply with quote
pass_strings works :D thanky everybody
PostPosted: Sat Jan 21, 2017 2:03 am     Reply with quote
Have you looked though, to understand 'why', and what the implications of this are?.
It is important 'long term', or you will find things like this coming back to 'bite you'.
marcoelmejor
PostPosted: Mon Jan 23, 2017 8:24 pm     Reply with quote
I'm reading books, some book recommendation? some advice to more knowledge?
PostPosted: Mon Jan 23, 2017 8:41 pm     Reply with quote
These two threads contain more explanation of the PIC architecture
by Ttelmah:
https://www.ccsinfo.com/forum/viewtopic.php?p=71942
http://www.ccsinfo.com/forum/viewtopic.php?t=34302&start=5
