sending integer pc to pic
doguhanpala
PostPosted: Thu Jan 19, 2017 5:13 am     Reply with quote
Hello everyone,
I am trying to send an integer value to a pic from a pc. I managed to send and receive an integer between to 18f2550s. It worked, but i can't send integer from pc. I can't send 123 for example.
Here are my codes.
Transmit code:
#include <18F2550.h>
#DEVICE ADC=10
#fuses INTRC_IO,NOWDT,NOMCLR,NOPROTECT,NOLVP,NODEBUG,NOBROWNOUT,CPUDIV1,VREGEN
#use delay(clock=8000000)
#use rs232(baud=9600, xmit=PIN_C6,rcv=PIN_C7)
#define toint(c) ((int)((c)-'0'))
#include <stdlib.h>
#include <string.h>
#include <stdio.h>
setup_oscillator(OSC_8MHz);
int sayi=253;
while (TRUE)
   output_high(PIN_A0); //1. pic haber veriyor
   output_low(PIN_A0);
   putc(sayi);
rcv code
#include <stdlib.h>
#include <string.h>
#include <stdio.h>
int sayi=0;
while (TRUE)
sayi = getc();
   if (sayi==253)
      output_high(PIN_A1);  //blink green led
      output_low(PIN_A1);
      output_high(PIN_A0);  //blink red led
      output_low(PIN_A0);
So i tried to send an integer from pc but no luck. The moment when i press a button it sends it automatically since it waits for a char. How can i send an integer? Why it works between 2 pics but not with pc?
thank you so much!
best wishes
Doğuhan
PostPosted: Thu Jan 19, 2017 7:20 am     Reply with quote
What program are you using on the PC to send data to the PIC? CCS' SIOW has a "hex window" at the bottom of its screen. For instance, to send 0xff, you just type "ff" into that window and hit the send button to the right.
I suspect that you need to first translate your number to hex, then type that hex equivalent into whatever program you're using.
PostPosted: Thu Jan 19, 2017 8:17 am     Reply with quote
or (of course), if you want to convert ASCII text to a 'number', then look at the CCS supplied functions in input.c 'get_int' for example....
doguhanpala
PostPosted: Fri Jan 20, 2017 7:15 am     Reply with quote
Thank you both. I use putty to receive and send data. I will search for get_int.
