art
| CDC Bootloader problem |
Posted: Thu Dec 29, 2016 4:21 am |
I'm using CCS compiler v5.015 and I'm using Window 7 64bit.
I've tried to install the driver when it prompt "CDC Bootloader" at my device manager. I've pointed it to the "Driver" folder in my PICC and try to install it. The problem is, it will indicate "Windows was unable to install your CDC Bootloader".
Please help me how to solve this problem.
This is the cdc_NTXPVista78.INF file:
; Windows 2000, XP and Vista setup File for CCS CDC demo
; see examples ex_usb_serial.c and ex_usb_serial2.c
[Version]
Signature="$Windows NT$"
Class=Ports
ClassGuid={4D36E978-E325-11CE-BFC1-08002BE10318}
DriverPackageDisplayName=%DESC%
Provider=%CCS%
LayoutFile=layout.inf
CatalogFile=cdc_NTXPVista78.cat
DriverVer=10/09/2013
[Manufacturer]
%CCS%=CCS,NTamd64
[CCS]
;%CCS_CDC%=Reader, USB\VID_0461&PID_0033 this was removed for WHQL certification since it's not CCS's VID
;%CCS_CDCBOOT%=Reader, USB\VID_0461&PID_0034 this was removed for WHQL certification since it's not CCS's VID
%CCS_E3MINI%=Reader, USB\VID_2405&PID_0006
%CCS_RAPIDUSB%=Reader, USB\VID_2405&PID_000e
%CCS_COMP_DEMO%=Reader, USB\VID_2405&PID_0007&MI_00
%CCS_COMP_DEMO2%=Reader, USB\VID_2405&PID_000a&MI_00
%CCS_CDC2%=Reader, USB\VID_2405&PID_000b
%CCS_CDCBOOT2%=Reader, USB\VID_2405&PID_000c
[CCS.NTamd64]
[Reader_Install.NTx86]
;Windows2000
[DestinationDirs]
DefaultDestDir=12
Reader.NT.Copy=12
; Windows 2000/XP/Vista-32bit Sections
[Reader.NT]
Include=mdmcpq.inf
CopyFiles=Reader.NT.Copy
AddReg=Reader.NT.AddReg
[Reader.NT.Copy]
usbser.sys
[Reader.NT.AddReg]
HKR,,DevLoader,,*ntkern
HKR,,NTMPDriver,,usbser.sys
HKR,,EnumPropPages32,,"MsPorts.dll,SerialPortPropPageProvider"
[Reader.NT.Services]
AddService = usbser, 0x00000002, Service_Inst.NT
[Service_Inst.NT]
DisplayName = %Serial.SvcDesc%
ServiceType = 1 ; SERVICE_KERNEL_DRIVER
StartType = 3 ; SERVICE_DEMAND_START
ErrorControl = 1 ; SERVICE_ERROR_NORMAL
ServiceBinary = %12%\usbser.sys
LoadOrderGroup = Base
; Vista-64bit Sections
[Reader.NTamd64]
Include=mdmcpq.inf
CopyFiles=FakeModemCopyFileSection
[Reader.NTamd64.AddReg]
[Reader.NTamd64.Services]
AddService = usbser, 0x00000002, Service_Inst.NTamd64
[Service_Inst.NTamd64]
[Strings]
CCS = "Custom Computer Services, Inc."
CCS_CDC = "CCS USB to UART"
CCS_CDCBOOT = "CCS CDC Bootloader"
CCS_E3MINI = "CCS E3 Mini Development Kit"
CCS_RAPIDUSB = "CCS Rapid USB Development Kit"
CCS_COMP_DEMO = "CCS HID/CDC Composite Demo"
CCS_COMP_DEMO2 = "CCS HID/CDC Composite Demo"
CCS_CDC2 = "CCS USB to UART"
CCS_CDCBOOT2 = "CCS CDC Bootloader"
Serial.SvcDesc = "USB Serial emulation driver"
DESC="CCS USB CDC Drivers"
Posted: Thu Dec 29, 2016 5:16 am |
It sounds as if you are not pointing at the correct driver, or your 'build' used the usb_desc_cdc.h file from an earlier version.
In CCS V5.013, the VID was changed from 0x461 to 0x2405. This later VID, CCS bought, and Microsoft then allowed them to include a .cat file with the driver, so it is seen as a 'signed' driver.
Now the inf file you post is the correct one for a post 5.013 build. However if your compile used the descriptor file from before this, it won't be recognised. Is the .cat file present in the directory with the inf file. It is needed.
In device manager, look at the device (will be marked with an exclamation mark, since there is no driver). What VID does it show?. it should be 2405. If it isn't, then your build used the old descriptor file.
Look at this thread:
<http://www.ccsinfo.com/forum/viewtopic.php?t=55524&highlight=usb+bootloader>
You will see that when he rebuilt making sure he was using all the newer files, it then worked. |
art
Posted: Thu Dec 29, 2016 4:08 pm |
Hi Ttelmah,
Yes, there is a cdc_ntxpvista78.cat file in the folder.
I've look in the device manager and it shows the CDC Bootloader with exclamation mark but there is no VID decription.
I've checked the usb_desc_cdc.h, and it show 0x0461.
Do I need to change it to 0x2405 to make it work?
#IFNDEF __USB_DESCRIPTORS__
#DEFINE __USB_DESCRIPTORS__
///////// config options, although it's best to leave alone for this demo /////
#ifndef USB_CONFIG_PID
#define USB_CONFIG_PID 0x0033
#ifndef USB_CONFIG_VID
#define USB_CONFIG_VID 0x0461
#ifndef USB_CONFIG_BUS_POWER
#define USB_CONFIG_BUS_POWER 100 //100mA (range is 0..500)
#ifndef USB_CONFIG_VERSION
#define USB_CONFIG_VERSION 0x0100 //01.00 //range is 00.00 to 99.99
//////// end config ///////////////////////////////////////////////////////////
#DEFINE USB_HID_DEVICE FALSE
#DEFINE USB_CDC_DEVICE TRUE
#define USB_CDC_COMM_IN_ENDPOINT 1
#ifndef USB_CDC_COMM_IN_SIZE
#define USB_CDC_COMM_IN_SIZE 11
#define USB_EP1_TX_ENABLE USB_ENABLE_INTERRUPT
#define USB_EP1_TX_SIZE USB_CDC_COMM_IN_SIZE
//pic to pc endpoint config
#define USB_CDC_DATA_IN_ENDPOINT 2
#ifndef USB_CDC_DATA_IN_SIZE
#define USB_CDC_DATA_IN_SIZE 64
#define USB_EP2_TX_ENABLE USB_ENABLE_BULK
#define USB_EP2_TX_SIZE USB_CDC_DATA_IN_SIZE
//pc to pic endpoint config
#define USB_CDC_DATA_OUT_ENDPOINT 2
#ifndef USB_CDC_DATA_OUT_SIZE
#define USB_CDC_DATA_OUT_SIZE 64
#define USB_EP2_RX_ENABLE USB_ENABLE_BULK
#define USB_EP2_RX_SIZE USB_CDC_DATA_OUT_SIZE
#include <usb.h>
/// start config descriptor
/// right now we only support one configuration descriptor.
/// the config, interface, class, and endpoint goes into this array.
#DEFINE USB_TOTAL_CONFIG_LEN 67 //config+interface+class+endpoint+endpoint (2 endpoints)
const char USB_CONFIG_DESC[] = {
//IN ORDER TO COMPLY WITH WINDOWS HOSTS, THE ORDER OF THIS ARRAY MUST BE:
// config(s)
// interface(s)
// class(es)
// endpoint(s)
//config_descriptor for config index 1
USB_DESC_CONFIG_LEN, //length of descriptor size ==0
USB_DESC_CONFIG_TYPE, //constant CONFIGURATION (CONFIGURATION 0x02) ==1
USB_TOTAL_CONFIG_LEN,0, //size of all data returned for this config ==2,3
2, //number of interfaces this device supports ==4
0x01, //identifier for this configuration. (IF we had more than one configurations) ==5
0x00, //index of string descriptor for this configuration ==6
#if USB_CONFIG_BUS_POWER
0x80, //bit 6=1 if self powered, bit 5=1 if supports remote wakeup (we don't), bits 0-4 unused and bit7=1 ==7
#else
0xC0, //bit 6=1 if self powered, bit 5=1 if supports remote wakeup (we don't), bits 0-4 unused and bit7=1 ==7
USB_CONFIG_BUS_POWER/2, //maximum bus power required (maximum milliamperes/2) (0x32 = 100mA) ==8
//interface descriptor 0 (comm class interface)
USB_DESC_INTERFACE_LEN, //length of descriptor =9
USB_DESC_INTERFACE_TYPE, //constant INTERFACE (INTERFACE 0x04) =10
0x00, //number defining this interface (IF we had more than one interface) ==11
0x00, //alternate setting ==12
1, //number of endpoints ==13
0x02, //class code, 02 = Comm Interface Class ==14
0x02, //subclass code, 2 = Abstract ==15
0x01, //protocol code, 1 = v.25ter ==16
0x00, //index of string descriptor for interface ==17
//class descriptor [functional header]
5, //length of descriptor ==18
0x24, //dscriptor type (0x24 == ) ==19
0, //sub type (0=functional header) ==20
0x10,0x01, // ==21,22 //cdc version
//class descriptor [acm header]
4, //length of descriptor ==23
0x24, //dscriptor type (0x24 == ) ==24
2, //sub type (2=ACM) ==25
2, //capabilities ==26 //we support Set_Line_Coding, Set_Control_Line_State, Get_Line_Coding, and the notification Serial_State.
//class descriptor [union header]
5, //length of descriptor ==27
0x24, //dscriptor type (0x24 == ) ==28
6, //sub type (6=union) ==29
0, //master intf ==30 //The interface number of the Communication or Dat a Cl [spam] interface, designated as the masteror controlling interface for the union.
1, //save intf0 ==31 //Interface number of first slave or associated interface in the union. *
//class descriptor [call mgmt header]
5, //length of descriptor ==32
0x24, //dscriptor type (0x24 == ) ==33
1, //sub type (1=call mgmt) ==34
0, //capabilities ==35 //device does not handle call management itself
1, //data interface ==36 //interface number of data class interface
//endpoint descriptor
USB_DESC_ENDPOINT_LEN, //length of descriptor ==37
USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05) ==38
USB_CDC_COMM_IN_ENDPOINT | 0x80, //endpoint number and direction
0x03, //transfer type supported (0x03 is interrupt) ==40
USB_CDC_COMM_IN_SIZE,0x00, //maximum packet size supported ==41,42
250, //polling interval, in ms. (interrupt endpoint cant be smaller than 10 for slow speed devices) ==43
//interface descriptor 1 (data class interface)
USB_DESC_INTERFACE_LEN, //length of descriptor =44
USB_DESC_INTERFACE_TYPE, //constant INTERFACE (INTERFACE 0x04) =45
0x01, //number defining this interface (IF we had more than one interface) ==46
0x00, //alternate setting ==47
2, //number of endpoints ==48
0x0A, //class code, 0A = Data Interface Class ==49
0x00, //subclass code ==50
0x00, //protocol code ==51
0x00, //index of string descriptor for interface ==52
USB_DESC_ENDPOINT_LEN, //length of descriptor ==53
USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05) ==54
USB_CDC_DATA_OUT_ENDPOINT, //endpoint number and direction (0x02 = EP2 OUT) ==55
0x02, //transfer type supported (0x02 is bulk) ==56
USB_CDC_DATA_OUT_SIZE & 0xFF, (USB_CDC_DATA_OUT_SIZE >> 8) & 0xFF, //maximum packet size supported ==57, 58
1, //polling interval, in ms. ==59
USB_DESC_ENDPOINT_LEN, //length of descriptor ==60
USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05) ==61
USB_CDC_DATA_IN_ENDPOINT | 0x80, //endpoint number and direction (0x82 = EP2 IN) ==62
0x02, //transfer type supported (0x02 is bulk) ==63
USB_CDC_DATA_IN_SIZE & 0xFF, (USB_CDC_DATA_IN_SIZE >> 8) & 0xFF, //maximum packet size supported ==66, 67
1, //polling interval, in ms. ==68
//****** BEGIN CONFIG DESCRIPTOR LOOKUP TABLES ********
//since we can't make pointers to constants in certain pic16s, this is an offset table to find
// a specific descriptor in the above table.
//the maximum number of interfaces seen on any config
//for example, if config 1 has 1 interface and config 2 has 2 interfaces you must define this as 2
#define USB_MAX_NUM_INTERFACES 2
//define how many interfaces there are per config. [0] is the first config, etc.
const char USB_NUM_INTERFACES[USB_NUM_CONFIGURATIONS]={2};
//define where to find class descriptors
//first dimension is the config number
//second dimension specifies which interface
//last dimension specifies which class in this interface to get, but most will only have 1 class per interface
//if a class descriptor is not valid, set the value to 0xFFFF
const int8 USB_CLASS_DESCRIPTORS[USB_NUM_CONFIGURATIONS][USB_MAX_NUM_INTERFACES][4]=
//config 1
//interface 0
//class 1-4
18,23,27,32,
//interface 1
//no classes for this interface
0xFF,0xFF,0xFF,0xFF
#if (sizeof(USB_CONFIG_DESC) != USB_TOTAL_CONFIG_LEN)
#error USB_TOTAL_CONFIG_LEN not defined correctly
/// start device descriptors
const char USB_DEVICE_DESC[USB_DESC_DEVICE_LEN] ={
//starts of with device configuration. only one possible
USB_DESC_DEVICE_LEN, //the length of this report ==0
0x01, //the constant DEVICE (DEVICE 0x01) ==1
0x10,0x01, //usb version in bcd ==2,3
0x02, //class code. 0x02=Communication Device Class ==4
0x00, //protocol code ==6
USB_MAX_EP0_PACKET_LENGTH, //max packet size for endpoint 0. (SLOW SPEED SPECIFIES 8) ==7
USB_CONFIG_VID & 0xFF, ((USB_CONFIG_VID >> 8) & 0xFF), //vendor id ==9, 10
USB_CONFIG_PID & 0xFF, ((USB_CONFIG_PID >> 8) & 0xFF), //product id, don't use 0xffff ==11, 12
USB_CONFIG_VERSION & 0xFF, ((USB_CONFIG_VERSION >> 8) & 0xFF), //device release number ==13,14
0x01, //index of string description of manufacturer. therefore we point to string_1 array (see below) ==14
0x02, //index of string descriptor of the product ==15
0x00, //index of string descriptor of serial number ==16
USB_NUM_CONFIGURATIONS //number of possible configurations ==17
/// start string descriptors
/// String 0 is a special language string, and must be defined. People in U.S.A. can leave this alone.
/// You must define the length else get_next_string_character() will not see the string
/// Current code only supports 10 strings (0 thru 9)
#if !defined(USB_STRINGS_OVERWRITTEN)
//the offset of the starting location of each string. offset[0] is the start of string 0, offset[1] is the start of string 1, etc.
char USB_STRING_DESC_OFFSET[]={0,4,12};
// Here is where the "CCS" Manufacturer string and "SERIAL DEMO" are stored.
// Strings are saved as unicode.
// These strings are mostly only displayed during the add hardware wizard.
// Once the operating system drivers have been installed it will usually display
// the name from the drivers .INF.
char const USB_STRING_DESC[]={
//string 0
4, //length of string index
USB_DESC_STRING_TYPE, //descriptor type 0x03 (STRING)
0x09,0x04, //Microsoft Defined for US-English
//string 1 - manufacturer
8, //length of string index
'C',0,
'C',0,
'S',0,
//string 2 - product
24, //length of string index
'S',0,
'E',0,
'R',0,
'I',0,
'A',0,
'L',0,
' ',0,
'D',0,
'E',0,
'M',0,
'O',0
#endif //!defined(USB_STRINGS_OVERWRITTEN)
#ENDIF
Posted: Thu Dec 29, 2016 8:18 pm |
Why don't you try it ? These are the values used in the current version
of the compiler, vs. 5.066. Try it and tell us what happens.
| Code: | #define USB_CONFIG_PID 0x000B
#define USB_CONFIG_VID 0x2405 |
Posted: Fri Dec 30, 2016 3:00 am |
Whoa a second.
The descriptor file you are posting is _not_ the one used by the bootloader. The bootloader uses use_desc_cdcboot.h
If you are using the standard serial descriptor, then 'no wonder' it won't work.
The descriptor for the bootloader (from your compiler version), is:
//// usb_desc_cdc.h ////
//// An example set of device / configuration descriptors for use with ////
//// CCS's CDC Virtual COM Port driver (see usb_cdc.h) ////
//// This file is part of CCS's PIC USB driver code. See USB.H ////
//// for more documentation and a list of examples. ////
//// Version History: ////
//// 10/28/05: ////
//// Bulk endpoint sizes updated to allow more than 255 byte ////
//// packets. ////
//// Changed device to USB 1.10 ////
//// (C) Copyright 1996,2005 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS ////
//// C compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, ////
//// reproduction or distribution is permitted without written ////
//// permission. Derivative programs created using this software ////
//// in object code form are not restricted in any way. ////
#include <usb.h>
#define USB_CONFIG_PID 0x000c
// config(s)
// interface(s)
// class(es)
// endpoint(s)
250, //polling interval, in ms. (cant be smaller than 10) ==43
USB_CDC_DATA_OUT_ENDPOINT, //endpoint number and direction (0x02 = EP2 OUT) ==62
// make8(USB_CDC_DATA_OUT_SIZE,0),make8(USB_CDC_DATA_OUT_SIZE,1), //maximum packet size supported ==64, 65
USB_CDC_DATA_OUT_SIZE & 0xFF, (USB_CDC_DATA_OUT_SIZE >> 8) & 0xFF, //maximum packet size supported ==64, 65
USB_CDC_DATA_IN_ENDPOINT | 0x80, //endpoint number and direction (0x82 = EP2 IN) ==55
// make8(USB_CDC_DATA_IN_SIZE,0),make8(USB_CDC_DATA_IN_SIZE,1), //maximum packet size supported ==57, 58
(USB_CDC_DATA_IN_SIZE+1) & 0xFF, ((USB_CDC_DATA_IN_SIZE+1) >> 8) & 0xFF, //maximum packet size supported ==64, 65
//config 1
//interface 0
//class 1-4
18,23,27,32,
//interface 1
0xFF,0xFF,0xFF,0xFF
//string 0
'C',0,
'C',0,
'S',0,
38, //length of string index
'C',0,
'C',0,
'S',0,
' ',0,
'C',0,
'D',0,
'C',0,
' ',0,
'B',0,
'O',0,
'O',0,
'T',0,
'L',0,
'O',0,
'A',0,
'D',0,
'E',0,
'R',0
#ENDIF
You will see that the device ID is different from the standard serial device (which is the numbers PCM_Programmer posted).
Understand that with 'signed drivers', everything must match, or Windows will not accept them. |
art
Posted: Fri Dec 30, 2016 8:03 am |
Hai Ttelmah and PCM,
Thank you very much both of you, I rewrite again the program and point to the correct usb_desc_cdc.h and it works. Right now I'm testing using windows 7 32 bit.... maybe tomorrow I will test it on 64 bit.
Thanks again |
