all ways to change pin output
nuclear__
PostPosted: Sun Dec 11, 2016 3:30 pm     Reply with quote
Hi there, probably the truth is out there but I cannot find it. A simple question.
Other that output_high(pin) what other way exist to set pins in boolean way?
For example how can I set a pin x high when pin y is low ( both outputs)?
Or to say that if pins x ,y (inputs) are both high,set w high too.
PostPosted: Sun Dec 11, 2016 3:37 pm     Reply with quote
1) you can read a port and use a 'mask' to set/reset individual pins when you write to that port.
2) you need to read the port, decide if x is high, then set y. similar proceedure to above
3) simple combination logic. Any 'C101' book should explain it
the CCS manual may have examples, the examples folder probably does and of course Google can find anything !
As there are several ways to do all of this, how you do it depends on several factors. PIC type, speed reqd, available memory,etc.
PostPosted: Sun Dec 11, 2016 3:45 pm     Reply with quote
From the CCS manual:
output_bit(pin, value)
Outputs the specified value (0 or 1) to the specified I/O pin.
output_float(pin)
Sets the specified pin to the input mode. This will allow the
pin to float high to represent a high on an open collector
type of connection.
output_drive(pin)
Sets the specified pin to the output mode.
nuclear__
PostPosted: Sun Dec 11, 2016 4:07 pm     Reply with quote
Can you give me an example in one statement;
I guess a= input_state(pin_a1);
And then how to use 'a' to set pin_a2?
PostPosted: Sun Dec 11, 2016 4:20 pm     Reply with quote
output_bit(pin_a2, a);
or maybe
output_bit(pin_a2, input_state(pin_a1));
I can't try. not on compiler computer...
edit...
33:  output_bit(testled, input_state(testin));
  00E6    B280     BTFSC 0xf80, 0x1, ACCESS
  00E8    D002     BRA 0xee
  00EA    9089     BCF 0xf89, 0, ACCESS
  00EC    D001     BRA 0xf0
  00EE    8089     BSF 0xf89, 0, ACCESS
  00F0    9092     BCF 0xf92, 0, ACCESS
this compiles so it should work....
testled is pin a0, testin is pin a1
PIC is 18F46k22
nuclear__
PostPosted: Sun Dec 11, 2016 10:23 pm     Reply with quote
Thank you both guys.
