Key hit start program
arelone
PostPosted: Mon Dec 05, 2016 4:45 pm     Reply with quote
I have a simple program to start blinking LED when 'a' from the keyboard is pressed.The program has no errors but the program does not start even 'a' has been pressed. I am using Pic18F4580, ccs c compiler ver 5.010, crystal 20MHz, win 10. Can't resolve the problem.
TQ
#include <18F4580.h>
//#device ADC=8
#use delay(clock=20000000)
   while(true)
    wait:
    while(!kbhit());
    if(getc()!='a')
    goto wait;
    output_low(PIN_B6);
    output_high(PIN_B6);
asmboy
PostPosted: Mon Dec 05, 2016 5:11 pm     Reply with quote
   while(true) {
    if (kbhit()) // {
        if (getc()=='a'){
         output_low(PIN_B6);
    }// if getcc
   } // end kbhit
  } // end while tru
} // end main
how bout that ??
asmboy
PLEASE don't let this be Proteus Isis ??
PostPosted: Mon Dec 05, 2016 5:41 pm     Reply with quote
first I'd need to KNOW the hardware is working so a 1Hz LED program needs to be cut/compiled/tested then...
some kind of
get data from PC, display on 'screen' program is next to do...
Aside from lots of WIN10 'issues', there's hardware issues like is this a REAL RS232 port or a USB<>TTL interface or ???
Also 'errors' MUST be added to the USE RS232(..options...)
'It doesn't work' can be broken down into 2 possibilites
1) bad hardware
2) bad software
#1 HAS to get fixed first....
arelone
PostPosted: Tue Dec 06, 2016 4:57 am     Reply with quote
I tested the code given however the problem remains. I tested with the code below which reads from 8 adc channels via UART and display the values in hyper terminal and it is working accordingly. If there is compatibility issue, what compiler version compatible with win10?
I want to test the code by pressing the start switch connected to RB0. Any examples?
#device ADC=8
#define button (PIN_B0)
  setup_adc_ports(ALL_ANALOG);
  setup_adc(ADC_CLOCK_DIV_64 | ADC_TAD_MUL_8);
  const int8 channel[] = 0, 1, 2, 3, 4, 5, 6, 7;
  int16 ADC_value[sizeof(channel)];
  int8 value;
  int16 voltage[sizeof(channel)];
  int z;
  SETUP_ADC_PORTS(ALL_ANALOG);
  output_low(PIN_B6);
  output_low(PIN_B7);
     for(z = 0; z < 1; z++)
      output_low(PIN_B6);
      // Collect all ADC data
      for(value = 0; value < sizeof(channel); value++)            // Read from 8 adc channels
        set_adc_channel(channel[value]);
        ADC_value[value] = read_adc();  // ADC readings
        voltage[value] = ADC_value[value] * (5000 / 255);         // Convert ADC data to mV
        output_high(PIN_B7);
      // Print all ADC data
      for(value = 0; value < sizeof(channel); value++)            // Display 8 voltage values
        printf("%4.3w\r\n", voltage[value]);
      printf("9\r\n");
PostPosted: Tue Dec 06, 2016 6:14 am     Reply with quote
1st , all versions of compiler will work with Win10, though YOU have to tell WIN10 a few things, here and there, that's one reason I still use XP, I don't have the time to setup Win10.
2nd, CCS does supply LOTS of examples,yup..in the examples 'folder', and they DO have a 'press-a-button-do-something' program in there.
3rd.
you still must add 'errors' to #use rs232(...options....)
( ) around PIN_B0 doesn't look correct
PostPosted: Tue Dec 06, 2016 11:29 am     Reply with quote
Have you ever proven that getc() works ? Try this simple rs-232 echo
program. See if you get back (on the terminal) the same key that you type.
Make sure you disable "local echo" in your terminal program for this test:
#use delay(clock=20M)
int8 c;
   c = getc();
   putc(c);
arelone
PostPosted: Tue Dec 06, 2016 4:49 pm     Reply with quote
Thanks for the reply. Can I know any links which can provide information on settings CCS in win10?
Tq
arelone
PostPosted: Tue Dec 06, 2016 5:02 pm     Reply with quote
I tested the rs-232 echo program and on the terminal display exactly the key I pressed. Any ideas what is exactly the problem?
TQ
Markdem
PostPosted: Tue Dec 06, 2016 7:08 pm     Reply with quote
First, disconnect the PIC from the PC and check you DO NOT get a echo back just to make sure local echo is turned off.
Then have a look at what input() does in the manual.
Using the code provided by PCM, make the echo come back only after pressing the button.
