Need help writing ccs c compiler program
jmbraightmeyer
PostPosted: Wed Nov 30, 2016 1:32 pm     Reply with quote
So I have a school assignment due and I have no idea what to do.
1 –With help from a potentiometer to simulate a temperature sensor, the LED turns ON only when the temperature is above 70 and is Off otherwise.
2-Use a push button switch to turn the LED off for 5 seconds at any time.
3-Use the WDT (Watch dog timer) or the overflow of another timer to achieve the timing in step 2 (above).
If anyone can help with even just the 1st part I would appreciate it.
I am using a PIC 16F690
PostPosted: Wed Nov 30, 2016 2:04 pm     Reply with quote
If you have the compiler, you have dozens of examples. Look in the examples directory. There are examples of reading a temperature, reading a keyboard, etc. etc..
You won't use the watchdog for the timing. It is too inaccurate on most PIC's, and just resets the chip. Just look at the delay function.
PostPosted: Wed Nov 30, 2016 2:32 pm     Reply with quote
I did a search of the forum for likely programs, using these search terms:
read_adc output_low output_high
and my name.
The sample code in this post is very similar to what you want for the first part:
Need Help Fuzz-C Code:
http://www.ccsinfo.com/forum/viewtopic.php?t=42952
PostPosted: Wed Nov 30, 2016 5:07 pm     Reply with quote
first step
Cut code for a 1Hz LED program and get it working !
Until that's working do NOT attempt the real project....
After that look at the examples CCS provides.....
to program any computer, you need to think like one.. figure out the steps and sequence, get one section working then build upon that.
Arakel
View user's profile Send private message Visit poster's website AIM Address
A similar code with PIC16F690
PostPosted: Fri Dec 02, 2016 2:54 pm     Reply with quote
This is like my thread. But my thread is with a real temperature sensor and a display.
http://www.ccsinfo.com/forum/viewtopic.php?t=55674
Yo! I love learning and technology! I just do not have experience so do not be angry if I ask a stupid question about a detail! From so much to remember sometimes I forget the details in order to remember the big problems!
