Array element and restart problem
doguhanpala
PostPosted: Wed Nov 30, 2016 3:57 am     Reply with quote
Hello everyone,
I made a 5x5 led matrix and i am using 18f2550 to use it. I wrote the code below and it works fine until i add 7th variable on the array. Is there something wrong with my fuse settings or something else?
Here is the code
#include <18F2550.h>
#fuses INTRC_IO, NOWDT, PUT, NOLVP,NOMCLR,NOPROTECT,NOLVP,NODEBUG,NOBROWNOUT,CPUDIV1,VREGEN
#device ADC=10
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
#define poz_1 PIN_A0
#define poz_2 PIN_A1
#define poz_3 PIN_A2
#define poz_4 PIN_A3
#define poz_5 PIN_A4
#define gnd_1 PIN_B1
#define gnd_2 PIN_B2
#define gnd_3 PIN_B3
#define gnd_4 PIN_B4
#define gnd_5 PIN_B5
int sondur =   0b1111100000;  //close all the lights
//these are letters
int16 Aharf[5] = {0b1001100001,0b0110100010,0b0000100100,0b0110101000,0b0110110000};
int16 Bharf[5] = {0b0001100001,0b0110100010,0b0001100100,0b0110101000,0b0001110000};
int16 Charf[5] = {0b0000100001,0b0111100010,0b0111100100,0b0111101000,0b0000110000};
int16 Dharf[5] = {0b0001100001,0b0110100010,0b0110100100,0b0110101000,0b0001110000};
int16 Eharf[5] = {0b0000100001,0b0111100010,0b0000100100,0b0111101000,0b0000110000};
int16 Fharf[5] = {0b0000100001,0b0111100010,0b0000100100,0b0111101000,0b0111110000};
int16 Gharf[5] = {0b0000100001,0b0111100010,0b0100100100,0b0110101000,0b0000110000};
int16 Hharf[5] = {0b0110100001,0b0110100010,0b0000100100,0b0110101000,0b0110110000};
int16 Iharf[5] = {0b0001100001,0b1011100010,0b1011100100,0b1011101000,0b0001110000};
int16 Jharf[5] = {0b1000100001,0b1101100010,0b1101100100,0b1101101000,0b0011110000};
int16 Kharf[5] = {0b0110100001,0b0101100010,0b0011100100,0b0101101000,0b0110110000};
int16 Lharf[5] = {0b0111100001,0b0111100010,0b0111100100,0b0111101000,0b0000110000};
int16 Mharf[5] = {0b0111000001,0b0010000010,0b0101000100,0b0111001000,0b0111010000};
int16 Nharf[5] = {0b0111000001,0b0011000010,0b0101000100,0b0110101000,0b0111010000};
int16 Oharf[5] = {0b1001100001,0b0110100010,0b0110100100,0b0110101000,0b1001110000};
int16 Pharf[5] = {0b0001100001,0b0110100010,0b0001100100,0b0111101000,0b0111110000};
int16 Rharf[5] = {0b0001100001,0b0110100010,0b0001100100,0b0101101000,0b0110110000};
int16 Sharf[5] = {0b1000100001,0b0111100010,0b1001100100,0b1110101000,0b0001110000};
int16 Tharf[5] = {0b0000000001,0b1101100010,0b1101100100,0b1101101000,0b1101110000};
int16 Uharf[5] = {0b0110100001,0b0110100010,0b0110100100,0b0110101000,0b0000110000};
int16 Vharf[5] = {0b0110100001,0b0110100010,0b0110100100,0b0110101000,0b1001110000};
int16 Yharf[5] = {0b0111000001,0b1010100010,0b1101100100,0b1101101000,0b1101110000};
int16 Zharf[5] = {0b0000000001,0b1110100010,0b1101100100,0b1011101000,0b0000010000};
int16 yazi[6] = {Rharf,Oharf,Bharf,Oharf,Tharf,Sharf}; // this is the image i try to write. If i write this it works.
// But if i write ROBOTSA the last letter 'A' becomes a weird figure.
// I thought it could be from of the array Aharf, but when i print SELAM, or A by it self, it still works right.
// The problem is it gets weird after the 7th element.
int16 i=0;
int16 k=0;
void sekilbas(int16);
void dizibas(int16 dizi[]);
   setup_oscillator(OSC_4MHz);
   while(TRUE){
      for(k=0;k<6;k++) //chooses the element from yazi[] array
       for(i=0;i<500;i++)
         dizibas(yazi[k]);      //calls the printing function and opens led for a time period
         sekilbas(sondur);  //closes all the leds after each letters printed
      sekilbas(sondur);
void sekilbas(int16 number)   //this gives the outputs the elements of array
      output_bit(PIN_B5,bit_test(number,9));
      output_bit(PIN_B4,bit_test(number,8));
      output_bit(PIN_B3,bit_test(number,7));
      output_bit(PIN_B2,bit_test(number,6));
      output_bit(PIN_B1,bit_test(number,5));
      output_bit(PIN_A4,bit_test(number,4));
      output_bit(PIN_A3,bit_test(number,3));
      output_bit(PIN_A2,bit_test(number,2));
      output_bit(PIN_A1,bit_test(number,1));
      output_bit(PIN_A0,bit_test(number,0));
void dizibas(int16 dizi[]) //this opens the leds row by row with little delay
      int i=0;
      for(i=0;i<5;i++)
            sekilbas(dizi[i]);
            delay_us(500);
I have another question. I write a code and upload it to the 18f2550 and see that it works. If i restart pic, the code gives weird random figures. After i upload the same code it works again. What might be the problem?
Thanks for help and sorry for bad english. If anything is unclear i can try to rewrite.
Doğuhan
Edit: changed the 6th element to 7th element, and i changed the variable in for loop to k<7
Edit2: hello again. i think i found the problem. it was about array dimensions. when i tried to increase the array size to 8 the compiler could not compile it. i think i did wrong when try to create an array of arrays.
so i changed the code to this.
#device ADC=10
int16 gulenyuz[3] = {0b1010100010,0b0111001000,0b1000110000};
int16 somurtanyuz[3] = {0b1010100010,0b1000101000,0b0111010000};
//int16 yazi[7] = {Rharf,Oharf,Bharf,Oharf,Tharf,Sharf,Aharf};
char yazi[8] = {'R','O','B','O','T','S','A','N'};
int16 i=0;
int16 k=0;
void elemansec(char dizi2[]);
         elemansec(yazi);
      int i=0;
      int16 k=0;
      for(k=0;k<500;k++)
         for(i=0;i<5;i++)
               sekilbas(dizi[i]);
               delay_us(500);
      sekilbas(sondur);
   int i = 0;
   for(i=0;i<sizeof(yazi);i++)
      switch(dizi2[i])
         case 'A': dizibas(Aharf); break;
         case 'B': dizibas(Bharf); break;
         case 'C': dizibas(Charf); break;
         case 'D': dizibas(Dharf); break;
         case 'E': dizibas(Eharf); break;
         case 'F': dizibas(Fharf); break;
         case 'G': dizibas(Gharf); break;
         case 'H': dizibas(Hharf); break;
         case 'I': dizibas(Iharf); break;
         case 'J': dizibas(Jharf); break;
         case 'K': dizibas(Kharf); break;
         case 'L': dizibas(Lharf); break;
         case 'M': dizibas(Mharf); break;
         case 'N': dizibas(Nharf); break;
         case 'O': dizibas(Oharf); break;
         case 'P': dizibas(Pharf); break;
         case 'R': dizibas(Rharf); break;
         case 'S': dizibas(Sharf); break;
         case 'T': dizibas(Tharf); break;
         case 'U': dizibas(Uharf); break;
         case 'V': dizibas(Vharf); break;
         case 'Y': dizibas(Yharf); break;
         case 'Z': dizibas(Zharf); break;
         default: sekilbas(sondur); break;
i know it is a very simple and amateur way to drive a led matrix but i hope it will be useful to someone.
Best wishes
Doğuhan
PostPosted: Wed Nov 30, 2016 6:03 am     Reply with quote
Change the declarations for the matrix drive data, so:
to 'const int16'.
This data is constant, and this will save you several hundred bytes of RAM....
doguhanpala
PostPosted: Wed Nov 30, 2016 7:03 am     Reply with quote
to 'const int16'.
Thank you so much Ttelmah. i tried to do it but i got this error. 'attempt to create a pointer to a constant'. i googled about it but most of the problems people face are about strings. i am trying to find an integer example and learn how access a constant integer in a function. i tried this
int16 const Aharf[5] = {0b1001100001,0b0110100010,0b0000100100,0b0110101000,0b0110110000};
//-----------------rest of the code
//and
case 'A': dizibas(const Aharf); break;
//and
case 'A': dizibas(const int16 Aharf); break;
either way, no luck.
if i can manage it it will be very useful. thank you for your help again.
PostPosted: Wed Nov 30, 2016 7:43 am     Reply with quote
For using pointers, you have to use rom, instead of const. Sorry. Smile
