Duplicate filename on Command Line
JerryR
PostPosted: Mon Nov 21, 2016 10:33 am     Reply with quote
I just installed 5.064 PCWH and get this error message when attempting to compile my, previous "compilable" project.
Duplicate filename on command line---
Any ideas?
Thanks group!
PostPosted: Mon Nov 21, 2016 3:14 pm     Reply with quote
Are you running from the command line or the IDE?.
Obvious suggestion, something has got explicitly included in the project 'settings' that is already included automatically, so two copies are being added when the compiler tries to run.
JerryR
PostPosted: Mon Nov 21, 2016 4:17 pm     Reply with quote
IDE (MPLab 8.90). Thanks for your interest!
gjs_rsdi
PostPosted: Mon Nov 21, 2016 8:33 pm     Reply with quote
When you get the:
Is not telling you at which line?
Best wishes
Joe
PostPosted: Tue Nov 22, 2016 5:57 am     Reply with quote
It's not complaining about a line in the code. MPLAB calls the command line CCS compiler. It builds a line to call this. For some reason, the code has got the same file built into the line twice...
I'd suggest that somehow the same file has got added twice to one of the MPLAB settings.
Really need to ask on an MPLAB forum.
JerryR
PostPosted: Tue Nov 22, 2016 6:32 am     Reply with quote
Thanks for your replies Ttelmah and Joe. This gives me a good enough guide to fix the issue. Best regards.
