100 expecting declaration error
naren
PostPosted: Fri Nov 18, 2016 10:46 am     Reply with quote
I'm doing a project that uses pic18f452 where i need to apply stopwatch application. Since i need to use ccs compiler when i compile the program but it had been showing me 100 error on expecting declaration. What should i do?
naren
PostPosted: Fri Nov 18, 2016 11:18 am     Reply with quote
The error messages will give you the line number in the program for each
error. Post the code starting at that line number, and also post a few
lines of code that occur before that line.
Do this for the first two error messages that you get.
PostPosted: Fri Nov 18, 2016 7:44 pm     Reply with quote
You should also look at the examples CCS supplies as there is a 'stopwatch' program, I think it's called 'ex_stwt.c' or something.... this is from memory.
naren
PostPosted: Sun Nov 20, 2016 3:55 pm     Reply with quote
thnx guys
naren
naren
NA
PostPosted: Sun Nov 20, 2016 4:05 pm     Reply with quote
I searched and it was there but i cannot access it. Can I know why?
naren
