ccs c pic16f88 port blink
tari
PostPosted: Tue Nov 15, 2016 12:48 pm     Reply with quote
/* port_blink.c
By Tarilayefa Edward
tarielect.edward@gmail.com
Date: 15/11/2016.
A simple port blinking code that flashes port a and b on/off
at the rate of t1 milliseconds.
Compiler: PCWHD Compiler v5.008
PIC16F88 used.
#include <16F88.h>  //include pic16f88 header file
void main(void) {
//#byte OSCCON = 0x60  //4MHz 0scillator
#byte OSCCON = OSC_4MHZ  //4MHz 0scillator
//#byte OSCCON = 0b01101000  //4MHz 0scillator
//#Fuses NOWDT,WDT,PUT,NOPUT,LP,XT,HS,EC_IO,INTRC_IO,INTRC,RC_IO,RC
#Fuses INTRC_IO             //internal osc used with a6, a7 as digital pins
#use delay(clock=4000000)  //4mhZ CLOCK SPEED
setup_adc(ADC_OFF);
set_tris_a( 0x00 ); //SET port a to output
OUTPUT_a(0x00);     //turn off porta
set_tris_b( 0x00 ); //SET port b to output
OUTPUT_b(0x00);     //turn off portB
int16 t1;     //declare t1 as 16bit variable (0 to 65535)
t1 = 1000;   //t1 in milliseconds
While(TRUE) {              //main loop
//OUTPUT_HIGH(PIN_B0); //turn on portb.0
OUTPUT_a(0xff);       //turn on porta
output_b(0xff);       //turn on portb
DELAY_MS(t1);         //delay for time t1 ms
//OUTPUT_LOW(PIN_B0); //turn off portb.0
output_b(0x00);       //turn off portb
DELAY_MS(t1);
