I2C LCD
Post new topic   Reply to topic    CCS Forum Index -> Code Library
sshahryiar
I2C LCD
PostPosted: Sat Sep 05, 2015 4:18 am     Reply with quote
PCF8574.h
#define PCF8574_address 0x40
#define PCF8574_write_cmd PCF8574_address
#define PCF8574_read_cmd (PCF8574_address + 1)
#define SDA_pin pin_A5
#define SCL_pin pin_A4
#use I2C(Master, SDA = SDA_pin, SCL = SCL_pin)
unsigned char PCF8574_read();
void PCF8574_write(unsigned char data_byte);
PCF8574.c
#include "PCF8574.h"
    unsigned char port_byte = 0;
    i2c_start();
    i2c_write(PCF8574_read_cmd);
    port_byte = i2c_read(0);
    i2c_stop();
    return port_byte;
    i2c_start();
    i2c_write(PCF8574_write_cmd);
    i2c_write(data_byte);
    i2c_stop();
LCD.h
#include "PCF8574.c"
#define clear_display 0x01
#define goto_home 0x02
#define cursor_direction_inc (0x04 | 0x02)
#define cursor_direction_dec (0x04 | 0x00)
#define display_shift (0x04 | 0x01)
#define display_no_shift (0x04 | 0x00)
#define display_on (0x08 | 0x04)
#define display_off (0x08 | 0x02)
#define cursor_on (0x08 | 0x02)
#define cursor_off (0x08 | 0x00)
#define blink_on (0x08 | 0x01)
#define blink_off (0x08 | 0x00)
#define _8_pin_interface (0x20 | 0x10)
#define _4_pin_interface (0x20 | 0x00)
#define _2_row_display (0x20 | 0x08)
#define _1_row_display (0x20 | 0x00)
#define _5x10_dots (0x20 | 0x40)
#define _5x7_dots (0x20 | 0x00)
#define dly 0x01
unsigned char data_value = 0x00;
void LCD_init();
void LCD_command(unsigned char value);
void LCD_send_data(unsigned char value);
void LCD_4bit_send(unsigned char lcd_data);
void LCD_putstr(char *lcd_string);
void LCD_putchar(char char_data);
void LCD_clear_home();
void LCD_goto(unsigned char x_pos, unsigned char y_pos);
LCD.c
#include "lcd.h"
void LCD_init()
    unsigned char t = 0x1A;
    data_value = 0x08;
    PCF8574_write(data_value);
    while(t > 0x00)
            delay_ms(dly);
            t--;
    data_value = 0x30;
    data_value |= 0x08;
    delay_ms(dly);
    data_value &= 0xF7;
    delay_ms(dly);
    data_value = 0x30;
    data_value |= 0x08;
    delay_ms(dly);
    data_value &= 0xF7;
    delay_ms(dly);
    data_value = 0x30;
    data_value |= 0x08;
    delay_ms(dly);
    data_value &= 0xF7;
    delay_ms(dly);
    data_value = 0x20;
    data_value |= 0x08;
    delay_ms(dly);
    data_value &= 0xF7;
    delay_ms(dly);
    LCD_command(_4_pin_interface | _2_row_display | _5x7_dots);
    LCD_command(display_on | cursor_off | blink_off);
    LCD_command(clear_display);
    LCD_command(cursor_direction_inc | display_no_shift);
    data_value &= 0xFB;
    LCD_4bit_send(value);
    data_value |= 0x04;
    unsigned char temp = 0x00;
    temp = (lcd_data & 0xF0);
    data_value &= 0x0F;
    data_value |= temp;
    data_value |= 0x08;
    delay_ms(dly);
    data_value &= 0xF7;
    delay_ms(dly);
    temp = (lcd_data & 0x0F);
    temp <<= 0x04;
    data_value &= 0x0F;
    data_value |= temp;
    data_value |= 0x08;
    delay_ms(dly);
    data_value &= 0xF7;
    delay_ms(dly);
    while (*lcd_string != '\0')
        LCD_send_data(*lcd_string);
        lcd_string++;
    LCD_send_data(char_data);
    LCD_command(goto_home);
void LCD_goto(unsigned char x_pos,unsigned char y_pos)
    if(y_pos == 0)
        LCD_command(0x80 | x_pos);
        LCD_command(0x80 | 0x40 | x_pos);
Example
#include <12F675.h>
#device *= 16
#fuses NOWDT, PROTECT, CPD, NOMCLR, INTRC_IO, BROWNOUT, PUT
#use delay (internal = 4MHz)
#include "lcd.c"
void setup();
    unsigned char i = 0;
    char txt1[] = {"MicroArena"};
    char txt2[] = {"SShahryiar"};
    char txt[6];
    setup();
        LCD_clear_home();
        for(i = 0; i <= 9; i++)
           LCD_goto((i + 3), 0);
           LCD_putchar(txt1[i]);
           delay_ms(99);
           LCD_goto((i + 3), 1);
           LCD_putchar(txt2[i]);
           delay_ms(99);
        delay_ms(4000);
        LCD_clear_home();
        LCD_goto(3, 0);
        LCD_putstr(txt1);
        for(i = 0; i <= 100; i++)
           LCD_goto(7, 1);
           sprintf(txt,"%02u", i);
           LCD_putstr(txt);
void setup()
    disable_interrupts(GLOBAL);
    setup_ADC(ADC_off);
    setup_ADC_ports(no_analogs);
    setup_timer_0(T0_internal);
    setup_timer_1(T1_disabled);
    set_timer0(0);
    set_timer1(0);
    LCD_init();
More details:
http://www.libstock.com/projects/view/1530/i2c-lcd
https://www.youtube.com/watch?v=dBjV9LTCY1c
https://www.facebook.com/MicroArena
SShahryiar
mahatia
PostPosted: Tue Nov 15, 2016 2:28 am     Reply with quote
hello! I am a student and the goal of my project is to interface date and hours from RTC DS1307 to the Lcd 16x2. I use PIC12F675 with an expander PCF8574. I ve used your codes to display something to the LCD and it works very well. Could you help me to do this? thank you very much! I really need it! please, help me![/img]
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
