PIC18f47J53 [Solved]
K M Saravanan
PostPosted: Tue Nov 08, 2016 4:23 am     Reply with quote
Hi all,
how can i flash pic18f47j53 using PICKIT2 (PICkit 2 v2.61) ?
Advance thanks to all.
PostPosted: Tue Nov 08, 2016 4:35 am     Reply with quote
Unfortunately MicroChip elected not to add new devices....
However people have worked on this:
<http://www.septillion.nl/index.php/add-unsupported-chips-to-the-pickit-2/>
This allows you to add more devices.
However here:
<http://wiki.pinguino.cc/index.php/PIC18F47J53_Pinguino>
Near the bottom of the page, there is a link to a zip file, which contains an updated devices.dat file supporting the 27J53, and the 47J53. Smile
K M Saravanan
PostPosted: Tue Nov 08, 2016 5:32 am     Reply with quote
Thank you very much for your reply
and now my ic is 3.6V Max voltage. How can i flash using this programmer ?
In programmer i check with multimeter that vcc pin giving +5V DC.
How can i connect my ic ?
PostPosted: Tue Nov 08, 2016 8:11 am     Reply with quote
Look at section 3.4.2 in the user guide.
<http://ww1.microchip.com/downloads/en/DeviceDoc/51553E.pdf>
You run the chip powered off 3.3v, not off the programmer.
gaugeguy
PostPosted: Tue Nov 08, 2016 11:04 am     Reply with quote
Unless it is a cheap PicKit 2 clone and not an actual PicKit 2.
K M Saravanan
PostPosted: Wed Nov 09, 2016 12:24 am     Reply with quote
So i need to connect separate power supply (3.3V) to PIC IC
And ICSP Programing Pin
Programmer - PIC IC
Pin1 - MCLR
Pin2 - No connection
Pin3 - Gnd
Pin4 - PGD
Pin5 - PGC
This is correct.
drolleman
PostPosted: Wed Nov 09, 2016 10:26 pm     Reply with quote
pin 2 must be connected to vcc of the chip
gjs_rsdi
PostPosted: Tue Nov 15, 2016 9:58 pm     Reply with quote
Thanks for the post Ttelmah.
After reading the link you have provided
I would like to bring out from retirement my PICKIT2 by adding a few MC, specifically the PIC18F46K22 and PIC16F1847.
I try to find the programming specifications for them by google and Microchip but didn't find.
Some idea where/how to find?
Best wishes
Joe
PostPosted: Wed Nov 16, 2016 5:09 am     Reply with quote
For the 46K22, it is 41398B.pdf, for the 1847, it is 41439A.pdf
The search should find it, but the problem is that the chip name is not just that for the chip. So for the second one (for example), the actual title is PIC16F/LF1847/PIC12F/LF1840 Memory Programming...
gjs_rsdi
PostPosted: Thu Nov 17, 2016 2:59 am     Reply with quote
Thanks again Ttelmah Smile
K M Saravanan
PostPosted: Tue Nov 29, 2016 10:51 pm     Reply with quote
Thanks to all,
Now i purchased PICKIT3. Now IC flashing.
Once again Thanks to all.
