Analog Read and Motor Drive 18F2550 SOLVED
doguhanpala
PostPosted: Fri Oct 07, 2016 4:40 am     Reply with quote
Hello
I try to analog read an optical encoder data, and drive motor according to that data. I tried these 2 codes and they are working. When i try to mix them, they don't. I think i am doing something wrong with the setup settings. Any ideas?
I use L293d motor drive and 18F2550.
Thanks and sorry for bad english.
My encoder code (this one works):
#include <18F2550.h>
#fuses INTRC_IO, NOWDT, PUT, NOLVP, HSPLL,NOMCLR,NOPROTECT,NOLVP,NODEBUG,NOBROWNOUT,USBDIV,PLL5,CPUDIV1,VREGEN
#device ADC=10
#use fast_io(A)
#define encoder_data PIN_A0
unsigned int16 ADC_read()   //adc read function
      unsigned int16 encoder_val=0;
      set_adc_channel(0);
      delay_us(10);
      encoder_val = read_adc();
      return encoder_val;
      set_tris_a(0x00000001);                    //RA0 input
      setup_adc_ports(AN0);
      setup_oscillator(OSC_4MHZ);
      output_a(0);
      int ADC_val=0;
      int change_counter=0;   //low high change counter
      byte change_STATUS=0;    //low high control status
      while(change_counter<=40)
            ADC_val = ADC_read();
            if(ADC_val<=100 && change_STATUS==0)
               OUTPUT_LOW(PIN_A5);
               change_counter++;
               change_STATUS=1;
            else if(ADC_val>100 && change_STATUS==1)
               OUTPUT_HIGH(PIN_A5);
               change_counter++;
               change_STATUS=0;
      output_high(PIN_A4);   //give warning that code has ended
      delay_ms(2000);
and my motor drive code (this works too):
#define enable_pin PIN_A3   //pin1 on l293d
#define motor_pin1 PIN_A1   //pin2 on l293d
#define motor_pin2 PIN_A2   //pin7 on l293d
void motor_forward()
      OUTPUT_HIGH(motor_pin1);
      OUTPUT_LOW(motor_pin2);
void motor_backward()
      OUTPUT_HIGH(motor_pin2);
      OUTPUT_LOW(motor_pin1);
void motor_stop()
            OUTPUT_HIGH(enable_pin);
            motor_forward();
            delay_ms(2000);
            motor_stop();
            motor_backward();
            delay_ms(2000);
            motor_stop();
and my final mix code (this does not work):
#device ADC=10
      set_adc_channel(0);
      delay_us(10);
      return encoder_val;
void motor_stop()
      set_tris_a(0x00000001);                    //RA0 giriş
      int ADC_val=0;
      int change_counter=0;   //low high değişimini sayan sayac
      byte change_STATUS=0;    //değişim olduğunu kontrol etme değişkeni
               motor_forward();
                        OUTPUT_LOW(PIN_A5);
                        change_counter++;
                        change_STATUS=1;
                        change_counter++;
                        change_STATUS=0;
                     motor_forward();
                     delay_ms(50);
         motor_stop();
         delay_ms(2000);
PostPosted: Fri Oct 07, 2016 7:02 am     Reply with quote
#device ADC=10
You have two oscillator fuses. Typically, HSPLL (with PLL5) is used if you
have an external 20 MHz crystal and want to run the PIC at 48 MHz.
INTRC_IO is typically used if you want to run the PIC without a crystal
and use the internal oscillator at 4 MHz.
What do you want to do ? If you don't want HSPLL, then remove that fuse.
PostPosted: Fri Oct 07, 2016 7:07 am     Reply with quote
also...seems a shame to run that PIC at only 4MHz as it can go a LOT faster allowing you to do more !
doguhanpala
PostPosted: Mon Oct 10, 2016 1:42 am     Reply with quote
#device ADC=10
thank you so much. it worked.
doguhanpala
can it go faster with internal clock? or should i use crystal?
PostPosted: Mon Oct 10, 2016 2:12 am     Reply with quote
Understand. This is a USB PIC, and to use USB, it _requires_ a crystal. If you are not using, and don't intend to use USB, then use another chip. You gain three more useable pins straight away....
You can go to 8MHz without a crystal, but not use USB.
The crystal it needs is 4, 8, 12, 16, 20 or 24MHz (it can run off external oscillators at 40, and 48MHz as well), but these are the values supported for a standard crystal.
With any of these oscillators/crystal, you can run the processor at the crystal frequency, or Fosc/2, /3, or /4, or at 48MHz, 32MHz, 24Mhz, or 16MHz.
Then the configuration is:
To run off the crystal frequency or a sub division of this, use 'XT' (for 4MHz), or 'HS' (for faster crystals). Then select CPUDIV to give this /1, /2, /3 or /4.
Select PLLx, to give 4Mhz from your selected crystal ('x' here is a division). So with a 12Mhz crystal, select PLL3. This is needed even if you are running straight off the crystal, if you intend to use USB.
To run at the 16, 24, 32 or 48MHz frequencies instead use XTPLL or HSPLL depending on the crystal frequency chosen.
Look at table 2-3 in the data sheet. This gives input frequencies in the left column. The next column is the PLLx number. The next the oscillator selection. Then the CPUDIV number, and finally the clock speed the CPU will run.
So with a 12MHz crystal, to run at 24Mhz, you use:
HSPLL, CPUDIV3, PLL3
This is the block of the table starting '12MHz', and then entry highlighted in black (this is because it is one of the entries that supports both low speed, and full speed USB).
doguhanpala
PostPosted: Mon Oct 10, 2016 2:17 am     Reply with quote
HSPLL, CPUDIV2, PLL3
Thank you so much! I am new to pic and probably asking really stupid questions. Thank you for your patience also.
PostPosted: Mon Oct 10, 2016 2:31 am     Reply with quote
A couple of other comments that haven't been made yet:
First, 'ADC_CLOCK_INTERNAL', is not recommended above oscillator speeds of 1Mhz. This needs a look at the data sheet.
Then you do realise that your current code, after 40 moves, will stop and die?. Won't then do anything.
Also, just select the ADC channel once. Then when you arrive back at the 'read' code, provided there has been at least 10uSec since the last time you read the ADC, you can just read it again straight away, without needing any delay.
doguhanpala
PostPosted: Mon Oct 10, 2016 4:14 am     Reply with quote
I know my code dies after 40 moves. It was for testing. Thanks for the warning. I had not realised i selected adc channel more than once. Thank you so much!
