[USB]Windows doesn't recognize the 18f4550
biomed12
PostPosted: Mon Sep 19, 2016 5:35 pm     Reply with quote
I want to use USB communication to communicate my 18f4550 and PC. I used the project wizard to create a project. Codes and header files here:
1-main.h file
#include <18F4550.h>
#device ADC=10
#FUSES NOWDT,XTPLL,PLL12                //No Watch Dog Timer
#use delay(clock=48MHz,crystal=4MHz,USB_FULL)
#define USB_CONFIG_VID 0x2405
#define USB_CONFIG_PID 0x000B
#define USB_CONFIG_BUS_POWER 500
#define USB_STRINGS_OVERWRITTEN
char USB_STRING_DESC_OFFSET[]={0,4,16};
char const USB_STRING_DESC[]={
   //string 0 - language
      4,  //length of string index
      0x03,  //descriptor type (STRING)
      0x09,0x04,  //Microsoft Defined for US-English
   //string 1 - manufacturer
      12,  //length of string index
      'K',0,
      'i',0,
      'r',0,
      'a',0,
      'z',0,
   //string 2 - product
      28,  //length of string index
      'M',0,
      'e',0,
      'd',0,
      'i',0,
      'c',0,
      'a',0,
      'l',0,
      'S',0,
      'e',0,
      'r',0,
      'v',0,
      'e',0,
      'r',0
#define USB_CONFIG_HID_TX_SIZE 63
#define USB_CONFIG_HID_RX_SIZE 63
#include <pic18_usb.h>
#include <usb_desc_hid.h>
#include <usb.c>
main.c file
#include <main.h>
/* TODO: Use usb_put_packet() to transmit data to USB HID,
using USB_HID_ENDPONT for the endpoint and the payload size
needs to match USB_CONFIG_HID_TX_SIZE. Use usb_get_packet()
to read incomming data, using USB_HID_ENDPOINT for the
endpoint. usb_enumerated() can be used to see if connected to
a host and ready to communicate. */
   usb_init();
      usb_task();
      //TODO: User Code
PostPosted: Tue Sep 20, 2016 5:02 am     Reply with quote
step 1... try the working examples that CCS supplies !
step 2.. be SURE D+ and D- ARE connected properly !!
step3 .. ONCE 1 and 2 are 100% working THEN 'go out on your own' and cut code.
USB is NOT easy unlike good old 'RS-232'. You NEED to have everything right for it to work.
PS be sure to READ and do what's in the comments in the example code and drivers......it's the 'details' you need to understand and do....
yup, I prefer good old RS232...HATE USB..
PostPosted: Tue Sep 20, 2016 9:22 am     Reply with quote
The .inf file for the CCS VID/PID is in a subdirectory off the examples folder. If Windows asks for a driver, it needs to be pointed at this. The string descriptor is meant to match the one in this file, or Windows will not accept it. The file itself, has to be approved by MS to be accepted, and if you change the descriptor, it will no longer match the ID stored in the security info.....
You can manually modify the file, but then Windows will always complain that the driver is not approved.
biomed12
PostPosted: Tue Sep 20, 2016 2:33 pm     Reply with quote
Dear Jay,
I definitely agree with you about RS-232 but I have to accomplish this peripheral to my MCU-devices to make it more efficient. As you know RS-232 ports no longer exist in modern computers. I don't want to use any additional peripheral no longer.
I think this problem related to win10. I will install win7 and try to solve problem for win10.
Thanks.
PostPosted: Tue Sep 20, 2016 2:44 pm     Reply with quote
As Mr T points out, you need to give Windows (any version +-) the correct information and it will work. I used the CCS examples on XP pro and home without problems...
Nowadays I don't use the 4550 for several reasons...
PostPosted: Wed Sep 21, 2016 1:41 am     Reply with quote
As I have already pointed out the problem is security.
Windows10 (and the later releases of W7, to a slightly lesser extent), will now only allow 'secured' drivers to be used. CCS supply one for their VID/PID/Name combination, but you are changing the name, which means the security certificate is invalid.....
If you want your own name, you will need to buy a PID/VID combination, and generate a new .inf file to match this, and then get a security certificate for this.
Otherwise just use the CCS example name.
