peppapig
| EEPROM 18F87K22 PROBLEM |
Posted: Fri Sep 16, 2016 6:13 am |
PIC: 18F87K22
COMPILER: PCWHD 4.114
Hello guys,
I have a weird situation with my internal eeprom.
My program always save the last data in all positions of eeprom, i believe that must be a problem with my compiler, take a look at my code.
My variable always return 104 in all position, like he always save the last data of write_eeprom in all position of my memory.
| Code: | #include "configuracao.c"
unsigned int leitura;
printf("Start... \n\r");
while(true)
write_eeprom (1, 29);
write_eeprom (40, 104);
leitura = 0;
leitura = read_eeprom(1);
printf ("%u", leitura);
delay_ms(2000);
| Code: | /*configuracao.c*/
#include <18F87K22.h>
#fuses HSH,NOPROTECT,INTRC_IO
#use delay(clock=8M)
#use rs232(baud=9600, xmit=pin_g1, rcv=pin_g2, parity=N, stop=1)
//PORT A
#use fixed_io(a_outputs = pin_a4,pin_a5,pin_a6,pin_a7)
//PORT B
#use fixed_io(b_outputs = pin_b1,pin_b2,pin_b3,pin_b4,pin_b5,pin_b6,pin_b7)
//PORT C
#use fixed_io(c_outputs = pin_c0,pin_c1,pin_c2,pin_c3,pin_c4,pin_c5,pin_c6,pin_c7)
//PORT D
#use fixed_io(d_outputs = pin_d0,pin_d1,pin_d2,pin_d3,pin_d4,pin_d5,pin_d6,pin_d7)
//PORT E
#use fixed_io(e_outputs = pin_e0,pin_e1,pin_e2,pin_e3,pin_e4,pin_e5,pin_e6,pin_e7)
//PORT F
#use fixed_io(f_outputs = pin_f1,pin_f2,pin_f3,pin_f4,pin_f5,pin_f6,pin_f7)
//PORT G
#use fixed_io(g_outputs = pin_g0,pin_g3,pin_g4)
//PORT H
#use fixed_io(h_outputs = pin_h0,pin_h1,pin_h2,pin_h3,pin_h4,pin_h5,pin_h6,pin_h7)
//PORT J
#use fixed_io(j_outputs = pin_j0,pin_j1,pin_j2,pin_j3,pin_j4,pin_j5,pin_j6,pin_j7)
#byte porta = 0x05
#byte portb = 0x06
#byte portc = 0x07
#byte portd = 0x08
#byte porte = 0x09
#byte portf = 0x10
#byte portg = 0x11
#byte porth = 0x12
#byte portj = 0x13 |
Posted: Fri Sep 16, 2016 2:47 pm |
don't know about the eeprom but the I/O ports are not at 05h ...13h, ,according to the datasheet that are at 0f80h...0f85h according to table 6-2,page 101.
guy
Posted: Sat Sep 24, 2016 1:06 pm |
| Quote: | | My program always save the last data in all positions of eeprom |
I doubt it. Most probably the read_eeprom is getting an old value from the register. Send us the .LST file or upgrade the compiler.  |
Posted: Mon Sep 26, 2016 7:06 am |
There are lots of problems even with the code incomplete.
First the addresses for the registers have been copied from a PIC16, and are invalid for a PIC18. Duh.
Why these are being used at all (especially given all the fixed_io statements, which these will bypass), is questionable, but if they are needed, they need to be corrected. Temtronic has pointed this out.
Then the fuses are wrong. First, two oscillators being selected (INTRC, and HSH....), and some basic settings missing. It looks like the code has been 'cut and pasted' from something from a basic PIC16, with no attempt to handle the hardware differences of the PIC18, and with stuff set wrongly.....
Then we have the big one, that this is a very early compiler for this chip. The 87K22, was only released in 2010, and guess when 4.114 dates from....
The first CCS compiler with this chip was about 4.112, and generally many functions were often 'not right' for the first few releases when a chip came out in those days.
Compiled with 4.118, with some working fuses, the code runs fine.
#fuses NOPROTECT, INTRC_IO, SOSC_DIG, NOXINST, NOWDT, NOEXTADDRSFT, NOFCMEN
#fuses NOIESO
#use delay(clock=8m)
#use rs232(baud=9600, UART1, parity=N, stop=1)
int8 leitura;
while(true)
leitura = 0;
printf ("%u\n", leitura);
delay_ms(2000);
Prints 29 |
