Count How many times program goes into interrupt
Micro_Guy
PostPosted: Wed Sep 07, 2016 3:29 am     Reply with quote
Hi guys,
I'm trying to figure out a way how to count how many times a program executes an ISR.
Here's the best I could come up with, but it's not working.
Any help/mentoring is greatly appreciated. I'm new to interrupts so I'm experimenting.
Thanks in advance!
#include <16F877A.h>
#use delay(clock = 4M)
int8 Count=0;
#INT_TIMER2
void control_timer_isr() {
   output_toggle(pin_C2);
   Count++;
setup_timer_2(T2_DIV_BY_16, 245, 5);
PostPosted: Wed Sep 07, 2016 4:41 am     Reply with quote
What you post will work.
How are you testing this?.
The interrupt will be called just over 50* per second.
4000000/(4*246*5*16) = 50.813
Micro_Guy
PostPosted: Thu Sep 08, 2016 12:54 am     Reply with quote
I'm testing this by running the program in Step mode and monitoring the value of "Count".
I think something weird was going on with my compiler because the code seems to update "Count" just fine now.
Thanks for the quick reply Ttelmah!!!
PostPosted: Thu Sep 08, 2016 1:45 am     Reply with quote
I actually 'guessed' you might be in a debugger.
These can sometimes introduce slight 'oddities'. This is why sometimes it is better to actually do things like have the code run for a second, and then print 'count', to fully understand how things work.
