MPLAB Configuration window
gjs_rsdi
PostPosted: Fri Aug 19, 2016 5:06 pm     Reply with quote
The MPLAB v8.92 CCS PCM C Compiler, Version 5.062 the window that used to be RELEASE or DEBUG is empty.
Also Project>Build Configuration widow shows: (No Build Configurations)
Project>Build Options.. is OK
Have some solution for the subject?
I am afraid I will have again problems with the configuration bits as I had with the DEBUG/RELEASE selection
Best wishes
Joe
PostPosted: Fri Aug 19, 2016 6:38 pm     Reply with quote
In the past, this problem would be solved if you installed the CCS plugin
for MPLAB vs. 8.xx:
http://www.ccsinfo.com/downloads/setup_mplab_plugin.exe
gjs_rsdi
PostPosted: Fri Aug 19, 2016 8:32 pm     Reply with quote
Thank you PCM programmer, always helpful answers Smile
The plugin from your link solved the problem.
Best wishes
Joe
PostPosted: Sat Aug 20, 2016 6:54 pm     Reply with quote
Just remember to compile in 'release' mode else the PIC won't work right in the real World !
gjs_rsdi
PostPosted: Sun Aug 21, 2016 1:32 pm     Reply with quote
Yes Jay and I can't forget the Debug/Release issue.
I spent two months trying to figure out why my program was working wrong until asked and PCM programmer wrote that it should be Release and not Debug. Sad
Best wishes
Joe
PostPosted: Sun Aug 21, 2016 2:45 pm     Reply with quote
Yeah, fun huh! I had a Microchip tech send me a 'patch' to force it to always be in release mode in the mid8 version of MPLAB. He couldn't understand why I NEVER use 'debug' mode.
I told him the 'Real World' is my debugging environment... I don't think he understood...
Oh well...
