Rotate pieces of code for each timer0 overflow
cleberalbert
PostPosted: Tue Aug 02, 2016 7:46 am     Reply with quote
Hello all!!
I'm using timer0 interruption to perform 4 actions (4 code blocks in the same interrupt service routine), but I want to execute only 1 action (1 block) for each timer0 overflow in order.
ex:
1st overflow: execute 1st block
2nd overflow: execute 2nd block
3rd overflow: execute 3rd block
4th overflow: execute 4th block
And so on...repearts forever.
Actualy my code executes all blocks (whole function) every timer0 overflow. How can I do to "rotate" the blocks?
Tks in advance!
My code:
#include <16F676.h>
#device ADC=10
#FUSES NOWDT
#FUSES INTRC_IO
#FUSES NOPUT
#FUSES NOPROTECT
#FUSES NOBROWNOUT
#FUSES NOMCLR
#FUSES NOCPD
#FUSES RESERVED                 //Used to set the reserved FUSE bits
#define OUT1   PIN_A5
#define OUT2   PIN_C1
#define OUT3   PIN_C2
#define OUT4   PIN_C3
#define OUT5   PIN_C4
#INT_RTCC
void  RTCC_isr(void)
   disable_interrupts(INT_RTCC);
   //BLOCK 1
   output_bit(OUT1, TRUE);
   delay_us(500);
   output_bit(OUT1, FALSE);
   //BLOCK 2
   output_bit(OUT2, TRUE);
   delay_us(750);
   output_bit(OUT2, FALSE);
   //BLOCK 3
   output_bit(OUT3, TRUE);
   delay_us(1000);
   output_bit(OUT3, FALSE);
   //BLOCK 4
   output_bit(OUT4, TRUE);
   delay_us(1250);
   output_bit(OUT4, FALSE);
   enable_interrupts(INT_RTCC);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_16|RTCC_8_bit);      //4,0 ms overflow
   while(TRUE);
cleberalbert
PostPosted: Tue Aug 02, 2016 8:08 am     Reply with quote
I got it! I'm rotating the blocks through a global variable to count how many overflow has already happened. I had tried it before and didn't work but it may be some mistake. Now is working :Smile :
This code is a prototype I wrote to simplify your understanding. Now I'll try to implement in my original code.
To rotate the blocks:
#include <16F676.h>
#device ADC=10
#FUSES NOWDT
#FUSES INTRC_IO
#FUSES NOPUT
#FUSES NOPROTECT
#FUSES NOBROWNOUT
#FUSES NOMCLR
#FUSES NOCPD
#define OUT1   PIN_A5
#define OUT2   PIN_C1
#define OUT3   PIN_C2
#define OUT4   PIN_C3
#define OUT5   PIN_C4
int count = 0;
#INT_RTCC
void  RTCC_isr(void)
   count++;
   switch(count)
      case 1:
            //BLOCK 1
            delay_us(250);
      case 2:
            //BLOCK 2
            delay_us(500);
      case 3:
            //BLOCK 3
            delay_us(1250);
      case 4:
            //BLOCK 4
            delay_us(1500);
            count = 0;
   while(TRUE);
PostPosted: Tue Aug 02, 2016 10:37 am     Reply with quote
Honestly though, why get involved in the overhead of an interrupt?.
Just poll the RTCC:
   int8 count=0;
   while(TRUE
       if (interrupt_active(INT_RTCC)
           clear_interrupt(INT_RTCC);
           switch(++count)
           case 1:
               //BLOCK 1
               output_high(OUT1);
               delay_us(250);
               output_low(OUT1);
           case 2:
               //BLOCK 2
               output_high(OUT2;
               delay_us(500);
               output_low(OUT2);
           case 3:
               //BLOCK 3
               output_high(OUT3);
               delay_us(1250);
               output_low(OUT3);
           case 4:
               //BLOCK 4
               output_high(OUT4);
               delay_us(1500);
               output_low(OUT4);
               count = 0;
PostPosted: Tue Aug 02, 2016 10:40 am     Reply with quote
you're 1/2way there.
you 'should' move your 'switch' code to main()
The ISR will 'say' the interrupt has happend and increment the counter variable. Your 'case' code will decide what to do.
Just be SURE to reset the counter variable after getting to 4 !
guy
PostPosted: Tue Aug 02, 2016 12:21 pm     Reply with quote
cleberalbert, please note that you should not disable/enable the interrupt in the interrupt service routine. All interrupts* are disabled and re-enabled automatically during interrupt handling.
* In more advanced PICs there are interrupt priorities where one interrupt can interrupt another.
gjs_rsdi
PostPosted: Tue Aug 02, 2016 4:29 pm     Reply with quote
As Guy has said, the compiler enables/disables interrupts so your enable disable is not necessary.
Ttelmah program big advantage is that you don't need to wait your delays inside the isr.
Best wishes
Joe
PostPosted: Wed Aug 03, 2016 12:25 am     Reply with quote
Best wishes
Joe
Slightly more than that. There is quite a bit of code involved in the interrupt handler (and time), to get to the interrupt routine. With the 'polled' code, the functions will be happening within just a couple of instruction times of the interrupt triggering, and the code will be smaller.
The delays in the ISR, in this case don't matter, since he is not using delays anywhere else!...
Polling the interrupt, will give smaller, and faster code. Very Happy
gjs_rsdi
PostPosted: Wed Aug 03, 2016 2:53 pm     Reply with quote
Two questions Ttelmah:
1. The interrupt itself is disabled if I understand correct?
2. If I have to do other things in the program that takes let's say 100us before back to main, my pooling can have this delay. Any way to avoid the delay?
From Ttelmah:
I will say quite a lot of time to enter/exit the isr. Some way to shorten it?
I forget how I was doing it in assembler Sad
Best wishes
Joe
