Pointer types don't match
BLL
PostPosted: Tue Jun 28, 2016 1:19 pm     Reply with quote
Hi, I have just moved to v5 compiler and I am getting the above warning and I don't see why. I didn't get in v4 or v3 and it is as in the help!
void download(char *p)
 int i = 0;
 char temp[10];
 float fTemp;
 while(*(p + i) != ',')
   fTemp[i] = *(p + i);
   i++;
 write_eeprom(4, atoi(fTemp));
 p += i + 1;
What am I missing?
Brian
PostPosted: Tue Jun 28, 2016 1:39 pm     Reply with quote
This is wrong in any compiler version.
fTemp, is a single floating point value. You try to access it as an array....
BLL
Pointer problems
PostPosted: Tue Jun 28, 2016 3:18 pm     Reply with quote
Hi, Sorry about that - my fingers!
Code should have read:
void download(char* p)
 int i = 0;
   temp[i] = *(p + i);
   i++;
 write_float_eeprom(0, atof(temp));
 p += (i + 1);
 i = 0;
temp is declared elsewhere as char temp[10];
Hope this makes more sense!
PostPosted: Tue Jun 28, 2016 3:45 pm     Reply with quote
You didn't post your PIC, or a test program, or your compiler version
so I don't know how you expect us to solve your problem.
Based on your previous posts, I put together the test program shown
below and compiled it with vs. 5.060. It compiles with no problems.
Executing: "C:\Program files\Picc\CCSC.exe" +FH "PCH_Test.c" +DF +LY -T -A +M -Z +Y=9 +EA #__buildcount__="0" #__18F2620=TRUE
Memory usage: ROM=3% RAM=3% - 4%
0 Errors, 0 Warnings.
Build Successful.
Loaded C:\Program Files\PICC\Projects\PCH_Test\PCH_Test.cof.
BUILD SUCCEEDED: Tue Jun 28 14:44:08 2016
#include <18F2620.h>
#fuses H4, NOWDT, PUT, BROWNOUT, NOLVP
#use delay(clock=40M)
#include <stdlib.h>
#include <internal_eeprom.c>
char temp[10];
 int i = 0;
   temp[i] = *(p + i);
   i++;
 p += (i + 1);
 i = 0;
int8 data[80];
download(data);
while(TRUE);
PostPosted: Tue Jun 28, 2016 11:40 pm     Reply with quote
There is a separate problem in the code as posted. No null terminator. When the ',' is seen, you need to write a 0 to the buffer, otherwise depending on what is already in 'temp', the return could be garbage.
#include <stdlib.h>
char temp[10];
   int i = 0;
      temp[i] = *(p + i);
      i++;
   temp[i]='\0'; //null terminate
   p += (i + 1);
   //writing 0 here is pointless i is set to 0 each time
   int8 data[80];
   download(data);
   while(TRUE);
BLL
PostPosted: Wed Jun 29, 2016 2:44 am     Reply with quote
Hi all, Thanks for replies. I am using the demo compiler 5.056d
Here is my test program. 18LF2620 at 10MHz:
#include <TestLCD.h>
#include <stdlib.h>
#include <string.h>
#include <math.h>
char temp[10];
float value;
//char LCDline0[21], LCDline1[21], LCDline2[21], LCDline3[21];
//LBV on AN0, LBI on AN1, Aquaroll on AN2, O/B tank on AN3
setup_adc_ports(AN0_TO_AN3|VSS_VDD);
setup_adc(ADC_CLOCK_INTERNAL|ADC_TAD_MUL_0);
setup_spi(SPI_SS_DISABLED);
setup_CCP1(CCP_OFF);
setup_CCP2(CCP_OFF);
setup_wdt(WDT_ON);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_timer_3(T3_DISABLED);
setup_vref(false);
setup_low_volt_detect(false);
//setup serial LCD117
fputs("?S0", lcd);   //no display screen on boot
fputs("?f", lcd);    //clear lcd
fputs("?G420", lcd); //4x20 LCD
fputs("?c0", lcd);   //no cursor
fputs("?BFF", lcd);  //display at full brightness
//define Euro symbol for LCD
fputs("?D003041E081E040300", lcd);
//define Pound symbol for LCD
fputs("?D10609081E08081F00", lcd);
//define ßeta symbol for LCD
fputs("?D20C12121412111116", lcd);
delay_ms(200);
fputs("Caravan monitoring?nunit, version 5.00?n(c) 2016 B.L. Lonnon", lcd);
delay_ms(2700);
delay_ms(200);
//warning here "Pointer types do not match"
strcpy(temp, "12.45");
value = atof(temp);
 for(;;)
The atof code is as per that in the help file!
Brian
PostPosted: Wed Jun 29, 2016 4:51 am     Reply with quote
OK.
First there are quite a few things wrong in what you post:
//Not recommended above 1MHz. Read the data sheet for the correct setting.
//Incorrect. Correct command is:
setup_spi(FALSE);
You are turning the SPI 'on', with slave select disabled.....
Then the fault is actually the declaration of atof in the stdlib.h file:
#define atof(s) strtof(s, 0)
Needs to be:
#define atof(s) strtof(s, (char *)0)
With the latest few compilers, CCS have 'tightened up' on warning about type changes between pointers when used.
BLL
Pointers
PostPosted: Wed Jun 29, 2016 5:36 am     Reply with quote
Hi Ttelmah
Thank you for that. I can only think wrong setup commands came from originally using a PIC16.
On stdlib.h - that's a CCS file so why haven't they corrected it on a compiler costing $600!!!!!!!! Don't they do testing?
Thanks for your help and I will go and play further!
Brian
