Bootloading 18LF2620
BLL
PostPosted: Sat Jun 25, 2016 8:21 am     Reply with quote
Hi, I am trying to use bootloading for the first time and am getting nowhere!
The PIC is a 18LF2620 and I have compiled and loaded ex_bootloader.c, having set the pin to check to A5.
I have then tried to transfer my program's .hex file, having grounded A5.
With teraterm, it uploaded the file to the PIC without errors but then on powering up my board with pin A5 now high, my program does not start.
I then tried using siow.exe with correct port settings and it reported port timeout and did nothing.
I tried ccsinfo and it said it couldn't find the programmer!
Since it uploaded with teraterm but didn't start the program, is the code in bootloader.c correct for the 18LF2620?
#if defined(__PCM__)
 #org LOADER_END+1,LOADER_END+10
#elif defined(__PCH__)
 #org LOADER_END+2,LOADER_END+20
void application(void)
  while(TRUE);
#if defined(__PCH__)
#org 0x40,0x7F
#else
#org 0x20,0x3F
  if(!input(PIN_A5)) //was B5
    load_program();
  application();
#ORG default
#int_global
void isr(void)
  jump_to_isr(LOADER_END+5*(getenv("BITS_PER_INSTRUCTION")/8));
I just have a pl2303 usb/serial device connected to the PIC's serial port on C6 and C7, which appears as COM12 in Windows. Baudrate is set to 9600.
Any help much appreciated.
Brian
PostPosted: Sat Jun 25, 2016 1:55 pm     Reply with quote
Vs. 5.059 doesn't have this in any ex_bootloader.c or ex_bootload.c file.
#org 0x40,0x7F
#else
#org 0x20,0x3F
I think it's from some older compiler version.
1. Post your compiler version.
2. Post your oscillator type and frequency.
3. Post the Vdd voltage of your 18LF2620.
BLL
Bootload 18LF2620
PostPosted: Sat Jun 25, 2016 3:14 pm     Reply with quote
Hi, My compiler is 4.110.
The Pic is on 5V, 10MHz xtal oscillator
PostPosted: Sat Jun 25, 2016 5:42 pm     Reply with quote
couple of comments...
going back a few steps...
1) Does the PIC actually work? Can you code/compile/run a 1Hz LED program to verify 'it's alive and well'?
I'd expect a PIC with JUST a bootloader installed to say flash an LED at 1 Hz just to PROVE the bootloader code itself is actually in there!
2) If you only have one compiler, get rid of the if defined ...compiler, set this else other compiler set these........
It can be confusing and really awkward to understand what and why the 'if' is for. I find it better to 'hard code', then again I also put comments on every line too !
BLL
Bootload 18LF2620
PostPosted: Sun Jun 26, 2016 1:51 am     Reply with quote
Hi, Thanks for the reply.
The PIC works - I have programmed it with my programmer with my large application and it works fine.
I can upload the .hex file with Teraterm, which suggests that the uploading is working? Since my program then isn't found, it seems to me to suggest that it is not jumping to the program's start location?
However, there is the further complication that siow won't upload the code!
I will tidy up the bootloader code, but I am not confident it will make a difference!
Brian
PostPosted: Sun Jun 26, 2016 3:48 am     Reply with quote
What is making pin A5 go high?.
You do realise you need a resistor to do this?.
PostPosted: Sun Jun 26, 2016 7:06 am     Reply with quote
I tried running this in hardware with vs. 4.110 and I think there must be
a bug in loader.c.
I programmed the HEX file for ex_bootloader.c in the 18F2620, and then
jumpered pin A5 to ground, and pressed the reset button. Then I used
Teraterm to "Send" the HEX file for ex_bootload.c to the PIC. I edited
both files to use only a 10MHz crystal with no PLL for now. I edited
Ex_Bootloader.c to use pin A5, the same as BLL does. Etc. I also got rid
of the printf statements in Ex_Bootload.c and substituted a few putc()
statements for simplicity.
After downloading the application HEX file (Ex_bootload.c), nothing
happens in TeraTerm. I used MPLAB vs. 8.92 to read the flash memory
in the PIC, so I could see what was actually downloaded to it.
Here's the memory starting at address 0x500, which is where the
application program is written by loader.c. Notice that it has chunks
of memory (8 instructions) that are full of NOP's. I think there is
something wrong with Loader.c for the 18F2620 for vs. 4.110.
Line  Address Opcode  Disassembly
   641   0500    EF88  GOTO 0x510
   642   0502    F002  NOP
   643   0504    FFFF  NOP
   644   0506    FFFF  NOP
   645   0508    FFFF  NOP
   646   050A    FFFF  NOP
   647   050C    FFFF  NOP
   648   050E    FFFF  NOP
   649   0510    6AF8  CLRF 0xff8, ACCESS
   650   0512    9ED0  BCF 0xfd0, 0x7, ACCESS
   651   0514    6AEA  CLRF 0xfea, ACCESS
   652   0516    6AE9  CLRF 0xfe9, ACCESS
   653   0518    96B8  BCF 0xfb8, 0x3, ACCESS
   654   051A    0E40  MOVLW 0x40
   655   051C    6EAF  MOVWF 0xfaf, ACCESS
   656   051E    0EA6  MOVLW 0xa6
   657   0520    FFFF  NOP
   658   0522    FFFF  NOP
   659   0524    FFFF  NOP
   660   0526    FFFF  NOP
   661   0528    FFFF  NOP
   662   052A    FFFF  NOP
   663   052C    FFFF  NOP
   664   052E    FFFF  NOP
   665   0530    6EB4  MOVWF 0xfb4, ACCESS
   666   0532    0E41  MOVLW 0x41
   667   0534    DFE9  RCALL 0x508
   668   0536    0E42  MOVLW 0x42
   669   0538    DFE7  RCALL 0x508
   670   053A    0E43  MOVLW 0x43
   671   053C    DFE5  RCALL 0x508
   672   053E    0E58  MOVLW 0x58
   673   0540    FFFF  NOP
   674   0542    FFFF  NOP
   675   0544    FFFF  NOP
   676   0546    FFFF  NOP
   677   0548    FFFF  NOP
   678   054A    FFFF  NOP
   679   054C    FFFF  NOP
   680   054E    FFFF  NOP
   681   0550    FFFF  NOP
Here is the Ex_bootload.c code that was compiled. This is what should
have been written to address 0x500:
   642   0502    F002  NOP
   643   0504    FFFF  NOP
   644   0506    FFFF  NOP
   645   0508    A89E  BTFSS 0xf9e, 0x4, ACCESS  // TXIF == 1 ?
   646   050A    D7FE  BRA 0x508  // Stay in loop until it is.
   647   050C    6EAD  MOVWF 0xfad, ACCESS  // write to TXREG
   648   050E    0C00  RETLW 0
   657   0520    6EAC  MOVWF 0xfac, ACCESS
   658   0522    0E90  MOVLW 0x90
   659   0524    6EAB  MOVWF 0xfab, ACCESS
   660   0526    50C1  MOVF 0xfc1, W, ACCESS
   661   0528    0BC0  ANDLW 0xc0
   662   052A    090F  IORLW 0xf
   663   052C    6EC1  MOVWF 0xfc1, ACCESS
   664   052E    0E07  MOVLW 0x7
   666   0532    0E41  MOVLW 0x41   // Putc('A');
   668   0536    0E42  MOVLW 0x42   // Putc('B');
   670   053A    0E43  MOVLW 0x43   // Putc('C');
   672   053E    0E58  MOVLW 0x58   // Putc('X');
   673   0540    DFE3  RCALL 0x508
   674   0542    D7FD  BRA 0x53e
   675   0544    0003  SLEEP
   676   0546    FFFF  NOP
   677   0548    FFFF  NOP
   678   054A    FFFF  NOP
   679   054C    FFFF  NOP
   680   054E    FFFF  NOP
   681   0550    FFFF  NOP
PostPosted: Sun Jun 26, 2016 8:25 am     Reply with quote
It could even be a bug with the 'write_program_memory' function.
4.110, was at a time where there were some odd bugs. I didn't bother to keep it, since I found that programs which were working around the 4.100 area, stopped working with some of the versions at this time....
I have a 'gap' in stored versions from 4.104 to 4.112, where I found too many things were not working to bother to keep them.
BLL
Bootload 18LF2620
PostPosted: Sun Jun 26, 2016 3:03 pm     Reply with quote
Hi all,
Yes, I have a 10K resistor from A5 to VCC and a switch to ground.
I think there is definitely a problem with CCS's bootload programs.
siow normally talks to my PIC fine - I send a character and it returns a comma delimited string.
However, when the bootload prog is running in the PIC and you try and upload the hex file with siow, it says it can't find the port! I haven't looked closely at their code but I guess that their PIC code is grabbing the port, so siow can't access it.
4.110 is the latest version I have, otherwise it's 3.249!
Brian
PostPosted: Mon Jun 27, 2016 12:57 am     Reply with quote
3.249, may well be better!....
V4, didn't work till about 4.070, then had 'bursts' of two or three working versions, followed by ones with bugs.
However, not sure that 3.249, would support the LF2620.
That being said, I don't think 4.110 does either. Proper support for the LF version wasn't fully added till about 2012, at around 4.13x.
As you will see, PCM_programmer was testing for the F2620, not the LF2620.
BLL
PostPosted: Mon Jun 27, 2016 9:20 am     Reply with quote
That's interesting. I thought that the differences between the F and LF versions were the ability of the LF to work down to 3.3V and reduced power consumption, so I presumed that it didn't matter if one selected the F device in code, but used it on an LF device.
Brian
PostPosted: Mon Jun 27, 2016 12:14 pm     Reply with quote
I tested vs. 4.141 and it worked OK. Vs. 4.141 was/is a pretty solid
version. If you want to use vs. 4, why not ask CCS support if they have
a low cost upgrade deal, where they upgrade you to vs. 4.141 for some
nominal charge ? Maybe they would do it.
If not, we can continue looking at the reason why 4.110 fails, and maybe
offer a work-around. But if you could skip all that by getting vs. 4.141,
it would be better.
Re: Bootloading 18LF2620
PostPosted: Mon Jun 27, 2016 1:18 pm     Reply with quote
Brian
On some PIC's, the version numbers and chip ID's are different. I don't think this is the case for this one. However there is one important 'feature', which is an answer to a question PCM_programmer has already asked. What is your Vdd?. The chips can't self erase below 3v, so you can't use a bootloader below this.
PostPosted: Mon Jun 27, 2016 2:14 pm     Reply with quote
He answered that in post #3. It's 5v. Once I saw that, I knew I could
easily test it with my 18F2620 and a PicDem-Plus board.
PostPosted: Mon Jun 27, 2016 2:31 pm     Reply with quote
Good. Missed that reply. Smile
As you say, makes it easy then to test.
I suspect it is a memory programming problem with his version. Have tried 3.249, and it programs OK.
There is also another issue. He talks about SIOW, not 'seeing' the port, when it is connected to the programmer. The bootloader does nothing to the port. It sounds rather as if he has another program open that is then interfering (only one device can actually talk to a standard comm port at any time).
Also he does need to have software handshaking enabled on the port, for bootloading.
