printf print broken message
odt133
PostPosted: Fri May 27, 2016 2:55 am     Reply with quote
Could anybody tell me what I did wrong?
I'm trying to use printf(). but not working properly.
Source code is like this.
#include "C:\Program Files (x86)\picc\devices\18F6520.h"
#use delay(clock=40000000)
#USE RS232(uart1, baud=9600, bits=8, parity=n)
#fuses H4,OSCSEN,BROWNOUT,BORV27,NOWDT,NOPROTECT,CCP2E7//config set1
void main( void )
   while( true )
      printf("led on.\r\n");
      output_high( pin_f7 );
      printf("led off.\r\n");
      output_low( pin_f7 );
and result from Tera Term is like this.
?幢
    슊+?幢
           +?幢
                슊+?幢
As you see, character is broken. I set tera term's baudrate as 9600.
What did I wrong? Please,,
Thank you in advance.
kWoody_uk
PostPosted: Fri May 27, 2016 4:04 am     Reply with quote
Check the basics:-
Is the LED flashing at the correct rate?
Keith
RF_Developer
PostPosted: Fri May 27, 2016 4:47 am     Reply with quote
Almost certainly not. The order of things is not right. Should be device.h, fuses, delay, then rs232 and the like (timers etc), then do user code.
#include <18F6520.h> // Use <> and select the right path in the project.
// Fuses MUST come before delay and use rs232, and they must come after the processor include. I have not checked these fuses are sensible.
// Use rs232 must come after use delay.
// Then other stuff.
PostPosted: Fri May 27, 2016 11:06 am     Reply with quote
also there needs to be a 'MAX232', TTL<>USB' or similar interface between PIC and PC.
PostPosted: Fri May 27, 2016 11:27 am     Reply with quote
and (of course) to give 40MHz, the crystal needs to be 10MHz. Back to 'does the LED flash at the correct rate'.
